Originally Posted by
audispeed
i would recomend the h-sports just for the convenience of the zerks fittings. you have to detach the nuespeed bar in order to lube the bushings. not that much work, but still a pain. that said, i have a nuespeed bar and like it (would go with h-sports if i had the choice to do it again).
I have the Neuspeed 19mm rear bar with their reinforcement brackets, and with it set to full stiff, it has been fine on street and track - my car is a 2001 S4 with 700/800 springs along with Ohlins coilovers plus the 4:1 center diff. On the track, the rear really hasn't gotten loose, except maybe if I ease off the throttle too quickly in a turn which I shouldn't be doing anyway.
I also have a Honda Civic full track car, and recently went to Energy Suspension greaseable sway bar bushings - they're sold by Amazon like these 3/4" ones (which are for the 19mm sway bar per Energy Suspensions' website). Anyway, here's the amazon ad:
http://www.amazon.com/Energy-Suspens...9232501&sr=8-2. On the Civic, it now takes say 1-2 minutes to give each bushing 3 squirts of Moly grease before a track event. I haven't installed these on my S4 yet, but there is limited room (muffler on left and cannister shaped thing on the right), but maybe 90 degree grease fittings could be installed and pointed downward. Main thing, is that the Energy Suspension bushings seem like they might work nicely on the Neuspeed sway bar. Note - the Amazon ad shows end links, but they are not included. - Jim
