Results 1 to 11 of 11
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    Suspension problems??
    Hey guys, so when I go over bumps there is a metal clicking noise coming from the wheels, it kinda sounds like if a bolt was loose and the washer was rattling.. However, I checked everything to make sure nothing was loose and everything seemed to check out ok.. any idea as of what this could be??
    i have h&r springs on the car.
    pic for fun
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Suspension problems??
    Nice car :)))
    Does the sound remind you of a lot of coins shaking in your glove compartment or some liek that?
    Might be anything, check the control arms (bushings) if u can.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Jan 23 2007
    2006 GTi, 1986 951, 2002 a4
    Norcal - Sac area
    I have this same problem in an 02 a4 3.0 quattro, that is completely stock.
    2006 GTI - APR K04 ~296 whp
    1986 951 - t4 50 trim ~373 whp
    2002 3.0Q A4 - Stock (Wife's)
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    See my post #9.... #9.... #9.... #9....
    http://www.audizine.com/forum/showthread.php?t=223698
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    x2, probably your brake pads. Had this, and it got worse when I installed my coilovers. Changed my brakes this weekend and that noise disappeared.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    You need a BBK - that's the problem
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
    May 27 2008
    IL
    so it's not causing any harm to the brakes or suspension?? im fine as long as i can deal with the noise right?
    Sep 13 2007
    Quebec, Canada
    Lived with it for around 8 months before changing my brakes. It that's your issue, it can be left that way.
    Jan 23 2007
    Norcal - Sac area
    oh sweet stuff, I was worried I'd have to like change out the control arm or something.
    May 21 2007
    Florida
    i had a knock when i did my springs/shocks and turned out i forgot a washer on top of the strut mount which acts as a spacer so they wouldnt knock around.
    2018 Navarro Blue Q5
    Veteran Member Three Rings dpatel's Avatar
    Oct 03 2005
    Atlanta, GA
    Quote Originally Posted by czero View Post
    If the noise goes away when you lightly tap your brakes than than it's most likely your pads. Try it going up a hill, down a hill, and on level ground.
    - 3.0 Quattro
    - Milltek Exhaust with 4" Tips
    - Hyperflow Intake
    - Caracter Front bumper
    - Eibach Pro Kit + Bilstein Sport Shocks and S4 Rear Sway
    - Sportec 18" wheels
    - Stoptech Slotted Rotors with Ceramic Pads
    - Level 10 VB & APR Snub Mount
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
