Results 1 to 4 of 4
    Jan 28 2005
    02 S4
    soCALI
    Brake Lube / Grease
    Can someone recommend a high temp brake grease? I'm using the black goo from kragen auto parts. It works great for a week or so of daily driving, or a couple of high speed stops, then squeaking comes back. I need something that holds up to the heat better. I'm running stoptech 355's w/ carbotech ax6 pads in the front and stock calipers w/ ferodo ds2500 in the back, if that matters.
    This stuff looks interesting, is it legit?
    http://www.gwrauto.com/Ceramlub.htm
    http://www.gwrauto.com/silencer/index.html
    Jan 28 2005
    02 S4
    soCALI
    Re: Brake Lube / Grease
    anybody? I guess what I'm referring to is also know as anti-squeal. So is everybody just using the packets that they sell at the counter of the auto parts store?
    Active Member Two Rings Boognish's Avatar
    May 31 2009
    junk
    Hackettstown, North NJ
    Maybe we can help each other out, I changed my rear brakes two months ago and used the dollar packets from autozone that looks purple on the parts, I used a lot more than recommended since a lot of the metal absorbs most of it if its rusted/corroded. I hope its just a lack of grease issue. BTW do you have any clue where I can find what bolt sizes are used for a front caliper/brackt on 99.5 A4 2.8 quattro?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    This is the best stuff I have found. works better than the grease. It's an elastomeric polymer that you apply to the back of disc brake pads to act as a vibration and sound absorbing layer. Available at most car parts stores.
