Results 1 to 4 of 4
    Veteran Member Four Rings ExpLlclT's Avatar
    Nov 24 2005
    1998.5 Audi A4 2.8LQ
    Bay Area CA
    VAG'ed car got code description wtf
    18010
    P1602 Power Supply (B+) Terminal 30 Low Voltage
    Address 01 -------------------------------------------------------
    Controller: 4D0 907 551 AH
    Component: 2.8L V6/5V MOTR HS D01
    Coding: 06201
    Shop #: WSC 06335
    1 Fault Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    whats B+ mean ?
    is that saying my ground was taken off
    1998.5 Audi A4 2.8LQM is what i got.
    pm for photoshoot
    www.flickr.com/photos/explicitphotography
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: VAG'ed car got code description wtf
    IIRC that means you're not supplying B+(Battery positive, 12V) at what ever terminal 30 is. Check the wiring, fuses, and crap. I'm not at work, so I'm really not sure what else to tell you.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Just clear it and see if it goes away... That code pops up if you disconnected the battery... If you did not, try checking your battery for corrosion or other various ground points, like the one behind the drivers side kick panel...
    ΜΟΛΩΝ ΛΑΒΕ
    Nov 24 2005
    Bay Area CA
    oo ok i was hopeing that was it. im good. no corrosion on this batt ill clear it it was because i disconnected it recently
    pm for photoshoot
