    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    wheels grinding when turning left...
    I'm getting this very annoying grinding sound whenever I turn left and/or making an U turn.
    I've looked at everything...tightening the suspension, taking off my wheels. It seems like its rubbing against the fender...but still not 100% sure
    also my upper arms seems cracked as well...but does this have anything to do with the grinding sound?
    anyways, Im bringing it to Penske tomorrow morning to dignose the friggin problem...the ride is lowered on Eibach pro/Bilstein
    any input will be greatly appreciated!
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: wheels grinding when turning left...
    If you're rubbing against the fender you should see the tire marks on the fender or fender liner. Usually its pretty loud.
    Most likely you have a blown control arm bushing that is squeaking when you turn. Nothing out of the normal.
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Mar 03 2008
    626 SoCal
    Im rubbing a bit...i can see slight paint rub off against the inner fender
    so its because of my upper control arm? but it only grinds when i turn left and U turn left...
    I did not have these problems with my LM TA reps...however after slapping on the works et28 in front...im gettin this...very frustrating and annoying
    "J Spec B7"
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    maybe a bad wheel bearing? That happened to me when I had a bad wheel bearing about 3 months ago.
    Mar 03 2008
    626 SoCal
    I'll have penske check it if that is the case...at this time im open for everything!!
    "J Spec B7"
