Results 1 to 21 of 21
Thread: A little teaser
    Feb 27 2005
    North Wales, PA
    A little teaser
    I found some motivation in me to get some shit installed on my Avant. I had all this stuff laying around but not time to mess with it. i still got to build my motor and install my gt30r. Thats for another post though. What i'm working on at the moment.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: A little teaser
    some thump in that trunk
    Stage 3+ RS6's
    Senior Member Two Rings DSM 2 Avant's Avatar
    Jan 02 2005
    Re: A little teaser
    Nice, you adding an amp too?
    B9 S5 SB | B8 S4 | R.I.P. 2001.5 A4 Avant
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    Re: A little teaser
    Please do a detailed work up on this if you can.
    You plan on making a fiberglass enclosor?
    How would you get signal from the existing stereo? Line level converter?
    Awesome
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Re: A little teaser
    That's exactly what I wanted to do, but according to some expert installers, it's a waste of money, unless you'll build a custom fiberglass enclosure which is very costly. On top of that the 6 inch sub is nothing extraordinary, though I am interested to see the progress and the final outcome.
    May 24 2008
    Orange County, NY
    Re: A little teaser
    I am so ready to do Fiberglass enclosours I even have resin and matt but just dont have the time or equipment to do the woodwork...
    Too bad you were not local I'd donate time and some material...
    Endorsing:
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Re: A little teaser
    can I have your stock sub?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Feb 27 2005
    North Wales, PA
    Re: A little teaser
    I'll take as many pics as I can. As it is now, there is too much volume for the JL 8W6. I chose this sub since its pretty shallow with some decent power (300rms). Yes I will be adding some amps and speakers as well. Two amps will be mounted in the spare wheel well. I have a JL 250/1 and a alpine 4 channel unit. When I get a matching JL 4 channel amp I'll make a nice false floor.
    I'm just using the stock woofer box as a base to make the new enclosure. As it sits now it appears that there is too much volume. Its gonna get hacked up a bit. I have the sub placed where I want it. I just need to do some cutting and making up some templates for the wooden front base to mount the sub. Then fiberglass the whole thing to reinforce it. I might be a little cleaner to start fresh and mold my own box from scratch but I would like to try this to see how it goes. Plus I get to use the stock mounting points and I can do most of the work out of the car.
    Feb 27 2005
    North Wales, PA
    Re: A little teaser
    Quote Originally Posted by SuperAvant View Post
    sure, what do you need it for?
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: A little teaser
    did you pull that out last night. I guess there is not enough room to fit it in stock location. When I went home I was thinking all about that w6 and I was thinking they never made a 8" in the w6 but its the older one so idk how you found on of thoes but good luck. How did you get out that side panel?
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Feb 27 2005
    North Wales, PA
    Re: A little teaser
    Its a discontinued sub. A bit hard to find but you can pick them up for under $150-$170
    The w7 is easy to find though. The side panel is held in by a ton of clips. Remove the flip up carpet bu taking the screws in the hooks near the seats. Then pull up the back latch trim. Then remove the screw where the cover hooks into. Then start yanking.
    May 24 2008
    Orange County, NY
    Re: A little teaser
    Hey I have a sub controller for JL amps sitting here on my desk, I got rid of the amps, ill sell it to you CHEAP.
    get at me.
    Z
    Endorsing:
    Feb 27 2005
    North Wales, PA
    Re: A little teaser
    how cheap is cheap?
    Also did some more work tonight. But too dark for pics on my phone. I made the front panel with the cut out and glassed it into the rest of the stock box. Its looking ok. I got lazy on the wood work and it shows. I also should have done more with wood cause glassing tight corners doesn't really have good results. Oh well. most of it is hidden anyways and its gonna get wrapped in suede. I still have to figure out the pin-outs on the stock connector that went to the stock sub amp. Maybe i'll do it at work when I can use an O-scope.
    May 30 2007
    MA
    Re: A little teaser
    Quote Originally Posted by Poopie View Post
    Is it still good? mine is blown...
    2014 R8 V10 - Gated
    Feb 27 2005
    North Wales, PA
    Re: A little teaser
    Yeah its still good. this is out of a 2001 avant...so i'm not sure how its gonna fit, etc.
    May 30 2007
    MA
    Re: A little teaser
    oh hmm...looks like it would fit and it looks like the same size...
    2014 R8 V10 - Gated
    Feb 27 2005
    North Wales, PA
    Re: A little teaser
    gimme a like 8 for shipping and you can have it and see if it works.
    Feb 27 2005
    North Wales, PA
    Re: A little teaser
    whooops...i severely miscalculated.
    I was gonna just mold in a ring....
    It didn't look right so I decided to cut out a panel
    put a layer of glass on and test fit....uugghh...its not centered. I'm making a trim piece anyways to hide the gaps and stuff anyways.
    i'm just gonna rework the hole to center it up more. I'm worried about space behind it though. I don't wanna bring my sub outwards anymore though. We'll see...
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Re: A little teaser
    Looks good Poopie, that's one way to get rid of Avant rattles, or add to them. Not really sure what you are going to end up with? More clean base or more rattles. Looks good...
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Feb 27 2005
    North Wales, PA
    Re: A little teaser
    I made some good progress the other night. Finished up the box pretty much. not pretty at all since there were so many angles. I used some thing fiberglass sheets to form the back side since i didn't want to mold back there. Its somewhat decent. I'm gonna put a few more layers of glass down to strengthen it up.
    Does anyone know the what the wiring to the sub looks like? I can't figure out which are the low level inputs to the stock amp. I hooked up the oscope and i can't get a defined answer.
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: A little teaser
    Might need you to make me something depending on what yours comes out to be like. I was looking around at seeing if I cant get a decent 6.5" sub to fit in the stock location with decent sound so I don't have to take up that space but if not im going the 8" route. as far as wiring goes I think it should be the same as any other sub if its not a dual voice coil.
