Results 1 to 7 of 7
    Registered Member Two Rings kingdon's Avatar
    Jul 07 2007
    new york
    My car is leaking antifreeze
    My car is leaking antifreeze some where under the car it looks like the antifreeze is coming from where the oil filter is some where around that area is there some where else the antifreeze could come from in that area I going to buy that entire part where the oil filter is connected to at the dealer tomorrow drop me a link with some feed back thanks guys.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: My car is leaking antifreeze
    Your oil cooler is cooled by coolant/anitfreeze. Pull off the three screws holding the coolant reservoir in place, grab a flashlight and look down by the oil filter.
    I've seen a couple that have cracked, or the cooler lines start deteriorating. That would be the first place I'd look.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    ^^^ what he said
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings SurferForever's Avatar
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    blacklight
    Natasha: 01 A4 2.0 T28/T04 || Silver (Fastest Color)
    034 Motor and Tranny Mounts | Full 3" exhaust with HFC | APR Snub | B&M Short Shifter | APR Boost Gage | RS4 Grill w/ Custom Matched Lowers | 8000k Headlights | 3000K Fogs | M3 Lip Spoiler | Reiger Roof Spoiler | Debadged | Clear Corner Mod | Independent Fogs | Dual Rear Fogs | Zimmerman Cross-Drilled Rotors | Mintex Pads | SS Braided Lines | 18X8 Black ASA AR1's
    Jul 07 2007
    new york
    Thanks guys I found the problem a coolant line behind the engine thats has a sensor for the antifreeze the sensor came out from the clip that holds it in place I re clip the sensor in and all is well now I am going on the high way to go play with some honda boys I like to let them run and pull them back in up stairs, any one want's to play cat and mouse.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    That might be the longest sentence of all time...
    Village Idiot!!!
    (\__/)
    (")_(")
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by Stampy View Post
    x2, haha
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
