Results 1 to 3 of 3
    Registered Member One Ring AUDI Neo's Avatar
    Jul 19 2008
    03 A4 1.8Tq
    Orlando, FL
    Help Needed: 2002 A4
    Hey Guys,
    I have a friend that is looking to buy an A4 from a friend of his. The car that he is looking at concerns me because of the following:
    there are oil marks all over the place. When I told the plastic cover off to look at the injectors and coil packs and I had oil on my hands just from that! I took a glance underneath the car and I saw oil where the turbo pipe meets the pipe that goes behind the bumper, and it was quite a bit (it was on the side of the turbo...not the side of the intercooler). It has not had a timing belt job done yet but he bought a timing belt kit. I told my friend to ask the guy when did he buy the car and how many miles were on it. I also told my boy to ask his friend how often did he change the oil, has there been any work done to it, etc. It's an 02 and it has 91,000+ miles on it. The guys is asking for 10k. Is there anything else i should be on the look out for? I personally don't think it's a good idea but I wanted other opinions.
    Thanks.
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Re: Help Needed: 2002 A4
    Get the records on the car. See what has been done, make damn sure the Timing Belt and all has been replaced. Probably bad seals and such in regards to the oil.
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2005 Porsche 911 997 Manual, 2022 Hyundai Tuscon
    Orlando, Florida USA
    I have an 02' as well: Look for if Timing belt has been done, Rack-n-pinion leaks (check the power steering fluid level), Oil coming from the turbo area, Axles (boots torn or leaking), Ask if the fluids have been changed (Rear diff, brake) and that should be it. Im at 71,xxx miles now and I've done all the above except the fluids.. And I need to.
    Current: 2022 E-Tron Sportback Premium Plus, Siam Beige, S-Line, Black Optic Package, 22x10.5 Q8 Rotors, 285/35/22 Continental DWS 06 PLUS
    TOY: 2005 Porsche 911 997 Carrara White / Black Interior 6 Speed manual, Aero Kit,
    BC Racing Coilovers, FABSpeed Exhaust, Headers & Intake, 991 GT3RS Reps "GOLD"
