Results 1 to 13 of 13
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Synthetic power steering fluid....and other maintenace issue?
    I went to do a routine fluid check on my S and noticed:
    * coolant fluid seems have exploded or spewed all over driver side portion of engine (water marks all over coolant tank, and engine parts) and was below minimum (i had just changed it two weeks ago)
    * oil needs to be topped
    * G 00200 hydraulic mineral oil is low
    I topped off coolant with mixture of water and G12, topped off oil.
    Now I'm concerned about the power steering fluid. Its 7pm and I have no idea where to buy Pentosin G 00200 hyd mineral fluid. Will it hurt if I substitute syntheic power steering fluid instead?
    Also...what are the reasons as to why my coolant fluid spewed all over the place?
    2015 B8 SQ5
    Click Here
    Past
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Re: Synthetic power steering fluid....and other maintenace issue?
    I would not put any PAS fluid into a B5, other than the specified type.
    Other fluids will attack your seals in pump and rack, not good.
    Oct 31 2005
    Ashburn
    Don't want to qoute it but i believe i was told the mineral oil used for the power steering was the same as the mineral clutch fluid. Off rte 7, Fairfax autoparts should have it. here's a pic, again i could be wrong so double check.
    - Instagram: @Sinister_rs5-
    Sep 05 2007
    Wood Dale, IL/Schaumburg, IL
    Sorry.....the CHF 11S is what you should be using. I confused the two, Affinitive is right don't mix the two.
    Use the CHF 11S.
    -Mike
    Current: 2009 Black Ford Mustang GT - Stock
    Sold: 2000 Audi S4 Quattro Sedan - Light Silver - Stock as hell.
    Sold: 2003 SVT Cobra Mustang - Sonic Blue - Not even CLOSE to stock.
    Jun 24 2008
    E46 M3
    Woodinville WA
    WHOA
    DO NOT ADD THE CHF 7.1 FLUID
    Your car will take the newer SYNTHETIC CHF 11S Fluid which comes in a green container. the 7.1 is not synthetic, just plain jane mineral. If need be you could also add CHF 202. 202 and 11S are compatible for mixing. 7.1 will cause more problems in the long run. mixing percautions are also printed on the containers.
    And most defintely do not add regular ATF or generic power steering fluid.
    C
    Oct 31 2005
    Ashburn
    ok, i was wrong. i did say check first. I was going off of what i heard...i haven't used this stuff except for when i got my clutch replaced the fluid was low.
    Veteran Member Three Rings CheesmoS4's Avatar
    Aug 24 2005
    Silver 01.5 Audi S4
    Northeastern OHIO
    y not just buy the audi power steering fluid, that is what i did to top mine off
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    op; affinitive is right. dont mix. use one or the other
    Jul 11 2007
    Chicago
    if not just do what I did and put that crap fluid in and then wait until your rack is spewing fluid all over your wheel wells and then take 10 hours and 300 or more dollars on replacing the Rack and Pinion...
    Old "Casa - 01 S4 - Homebrew Stage X - K03/16 - FMIC - Autospeed Motor Mounts/Tranny Mounts/DTS - Stern Power Ring/Rear Differential Poly - XS Power Exhaust - JHM Shifter/Solid Link/Delrin/3rd Detent/Homebrew Shifter Knobbie weight - Homebrew SMOC -"
    New "07 Infiniti Black Sedan G35s 6MT"
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    I have a maintenace question...how do you know when you need to change your differential fluid? Is there a warning light or anything? My output shaft seal is leaking and I don't want it to run dry before I replace it.
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by ThirdStrike View Post
    How do I know which fluid is currently in the resevoir? The mineral or synthetic...
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    there's no warning light for the diffy fluid as far as I know. You can check the fluid by removing the filler cap and sticking your finger in there to try and feel the fluid level. It should be right at the filler hole.
    My car is fast
    May 23 2008
    Columbia, SC
    Quote Originally Posted by IamEzraM View Post
    where is the filler cap?
