Results 1 to 19 of 19
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    how bad is rubbing?
    just got my coils installed and i am rubbing like a mad man, especially with passengers.
    how bad is it to rub? i imagine the tires take most of the beating? any threat to the car/suspension?
    in any event, i've got an appointment in a week to get raised and realigned.
    thanks!
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    May 22 2008
    2013 Audi S4 IceSilver MMI/SD/DSG/AK
    Bay Area
    Re: how bad is rubbing?
    I also had a rubbing issue, I removed screw that everyone talks about in the front. I also changed to 225 tires, and now I get no rub what so ever. I recommend this setup highly, I am 25.1 up front and 25 1/4 in the rear. I was also frustrated, but with a little work I got all the kinks worked out. What is your height? What is your wheel offset I assume 35 that is why I had trouble also.
    Ice Silver S4 Black Int. Sport Diff DSG, B&O, Nav, Advanced Key
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    i am at 25" in back and about 25.25 in front. rubbing is much more a problem in back.
    i have 35 offset, which actually looks great as i don't think it needed spacers to be flush.
    but i'm running 245 width tires, so they're running pretty flush with the fender.
    DUH! an Audi
    los angeles, CA
    ^^thats your problem, running flush isn't a good idea. I was running flush with 245 tires with spacers and it caused rubbing going drive ways....if you run 235 or 225 you would not have a problem...
    Also, tires will take the rubbing, just it will cause damage to the fender liners and potentially the fender itself. When the fender gets hit by the tire, it will cause the fender to start to be pointy. On my b5, I would rub and over a period of time the fender started to become sharp and it would slice my tires, slowly.... This is the only danger I can foresee happening. Say if you take a corner wayyyy to fast and your fender is sharp your tire COULD pop or rip a slice off the tire, thus needing you to replace it.
    -randy
    Jun 14 2005
    Anaheim, CA
    Fender roller is your friend. You should use it and see if it cures the problem.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    May 22 2008
    Bay Area
    I would recommend the smaller tires, really we have AWD cars and 225 is plenty to keep traction, also brand makes a huge difference go for Toyo Proxes 4's these tiers are narrower for some reason even on the 235. Also you can't really roll the rear fender so I recommend either getting smaller tires or get a higher offset. I could not be happier now that I don't rub, even fully loaded with 4 people and loaded back (I have avant) I have no rub even on the biggest bumps on these great CA roads.
    Feb 12 2004
    ‘23 RS5 Sportback '20 Q8 S-Line
    you can do the screw thing up front and the rears are most likely just the carpet in the wheel wells. Mine still do it a little. I would just wait, the tire will wear them down. You can also trim them. it wont damage the tire at all. I wouldnt suggest going with 225 tires. It actually decreases the overall diameter of the wheel. Your speedo is going to be off.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Its bad, really bad.
    Frame problems, tire wear, CV joints all sorts of problems, even torsen diff problems if one set of tires has more constant resistance that the other (aka one end of the car rubbing)
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    I've heard of people rubbing badly every day, and then where the tires contact the paint on the fenders heated it up so much the paint began to bubble and expose the bare metal. It makes your tires ugly so you have to sand them down smooth all the time, and will cut into your sidewall eventually and make the tire junk long before the tread wears off...
    Remove the screw, raise your coilovers, roll your fenders.
    Ignorance is bliss.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Yeah, seriously raise your rear up. Cause you've screwed up your car in 2 different ways and the rubbing is only an indicator that you've messed things up.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    raise is definitely coming. it's already scheduled as soon as i could get it in. just needed to know how little to drive between now and then.
    integration -- what are the two different ways? suspension is too low i assume is one... what's the other? thanks, you always seem to have the most insight on matters of suspension.
    Veteran Member Three Rings jayuuey's Avatar
    Aug 22 2007
    SF Bay Area
    did you get an alignment yet? i am wondering if this will help the rubbing issue.
    Jay
    Current: Ibis White A4 Avant S-line TI 2.0T MT6 (JHM STS, Unitronic Stage1)
    Sold and quickly forgotten: 09 Forester XT Limited
    Sold and will be missed: A4 2.0T Quattro, 6-speed manual, APR Stage 2+
    (old) norcal audizine GTGs, etc. http://www.flickr.com/photos/jayuuey/sets/
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    i did. i also got raised about half an inch. driving solo i don't get anymore rubbing. i have rubbed once when driving with 3 passengers + me, but it was a pretty big dip.
    i really need to step down to 235 on tire width though because i think i'd clear safely.
    Registered Member Two Rings
    May 29 2008
    TRINIDAD WEST INDIES
    had the same problem but i raised the rear and had min rubing nothing big and then took it for alignment and for some reason the rear lowered again and im back to bad rubbing going in again to raise , but that does not make sense ? alignment and the gap between the fender and tire is gone
    Feb 12 2004
    Quote Originally Posted by a4sdaride View Post
    prior to the alignment you most likely had alot of negative camber so the top of the wheels tucked into the fender. When they fixed it, the camber was adjusted out and the wheel rubbed again.
    Feb 12 2004
    Quote Originally Posted by a4dc89 View Post
    i dont think a quick brush of the tire on the carpet would be considered constant resistance...if his tire was dragging on metal enough to hinder the movement on the car then it may cause one of your problems.
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    I'm 25" front and rear with ET35 wheels 235 tires and no rubbing anywhere. Get a good alignment. I do have 1100lb springs in the rear and that may help too.
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    yeah, i'm 90% sure at 235 i would not rub. it's really close.
    Jun 14 2005
    Anaheim, CA
    There is a few different ways to fix the rubbing. Ill go from easiest to most difficult.
    1. Fender Rolling / Flaring
    2. Camber adjustment
    3. Raise the car slightly
    4. Change tire size
    -Charles@VMRWheels
    www.vmrwheels.com
