Results 1 to 10 of 10
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    coolant hose.. need OEM part number
    can someone get me the OEM part number for this coolant line?
    http://www.ecstuning.com/stage/edpd/...productID=2909
    id rather find it locally then get it shipped and wait for it to get here. thanks
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Re: coolant hose.. need OEM part number
    looks like 058 121 471b. good luck finding that at a dealer.
    contact via email please.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    ok great thanks. i have a print out from the dealership but their OEM connectors are dfifrent then what my gt28r is using so i wasnt sure. thanks for the info. might as well try and give them a call...
    -josh
    -josh
    Feb 27 2005
    North Wales, PA
    Just use generic hose from the auto store. are you making a coolant feed line?
    ^ yea man. just use some heater hose.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    its a coolant return line to the water pipe. runs along the front of the engine. Its a molded line now and it has some weird ass bends in it. not sure a generic hose will work without kinking it up. i will have to look at it more whne i get home.
    thanks
    josh
    -josh
    well i think all the people that have used generic heater hose, myself included, for their bt coolant lines will tell you that it works just fine.
    Registered Member Two Rings FourBlackRings's Avatar
    Jun 02 2008
    Monrovia, MD
    the one that runs right in front of the engine? just stop at your local auto repair shop and get generic hose it works fine you don't need the bends trust me i had the same problem when my original hose melted to the outlet on the engine.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    yea thanks for the help guys. bought the wrong size hose twice, gonna go back tommorrow and get the correct size. FYI 1/2in is to big. the hose says 5/16 but i think tahts the inside diameter. so tomorrow i go and get the correct size which i think is 3/8...
    -josh
    -josh
    Apr 22 2007
    Riverbank, Ca
    3/8 bro... mine got eatn by my pancake valve (hot and sharp dont mix w/ plastic when the DAPO twisted the line the wrong direction..)...
    Switch it with some good heater hose and you'll be golden for years.. Find out why its leaking and see if something was rubbing on it.. I put a metal bracket between my rub..
