Results 1 to 8 of 8
    Registered Member Two Rings audi77804's Avatar
    Sep 21 2007
    audi a4 2.8
    hartford CT
    losing coolant... why?
    my low coolant light keeps coming on. and i have had to top off my g12 like once or twice a month. why is this anyone know? its not leaking out in my garage anywhere and i dont see any leaks.
    Jun 20 2007
    Colorado
    Re: losing coolant... why?
    Everybody will say check the afterrun coolant pump under the intake manifold. It usually drips onto there and dries up. Shine a flashlight under there and look for crusty dried coolant.
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    i highly suggest you stop driving the car until you find out whats wrong.
    SBSC
    I also like to live dangerously.
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    did you check the coolant reservior? it might be cracked somewhere. i would check all of the hoses too.
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Veteran Member Three Rings tbone5446's Avatar
    Nov 16 2006
    b5s4, 85 4runner T3/T4 turboed
    San Diego
    if it has 4 rings it has coolant leaks, fact of life
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Problem solved: http://www.audizine.com/forum/showthread.php?t=213369
    I had the same issue. It was my coolant pump. Check out my thread.
    Veteran Member Three Rings Auburnsky1287's Avatar
    Jan 06 2008
    Orlando
    secondary coolant pump most likely
    2001 Audi S4
    Vast Tuned Stage 3
    Active Member Two Rings PA::S4new's Avatar
    Nov 16 2006
    PA
    Agree it's the auxillary coolant pump. I did mine without removing the intake manifold and it wasn't a bad job at all. There's a good write up on AW about it.
    Dave
