Results 1 to 14 of 14
    Senior Member Three Rings dirtyserby's Avatar
    Jan 28 2007
    Bay Area, Norcal
    Terrible metallic Rattle at idle- Help Diagnose??
    Just came back from a 3000km road trip. (will post pics in a bit)
    Car ran (and still does) beautifully, but I noticed this terrible metallic, clickign
    rattle from the front.
    Sounds like something is dislodged somewhere ...
    Hopefully its not a stuck lifter or something internal .
    It only happens at idle, and revving it just a bit gets rid of the noise. Other than that the car still runs fine, gets great mileage and boosts fine.
    here is the youtube link
    http://www.youtube.com/watch?v=lLqyXp7HAIw
    masters of AZ...help me again
    what could it be?
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Terrible metallic Rattle at idle- Help Diagnose??
    Quote Originally Posted by dirtyserby View Post
    what could it be?
    Hmm....is it just when the car starts or no matter what?
    Jan 28 2007
    Bay Area, Norcal
    Quote Originally Posted by audipotential View Post
    no... all the time at idle
    Veteran Member Four Rings PETARDED's Avatar
    Dec 19 2005
    Arlington, Va
    I have a weird one that comes on when its cold, then disappears, it sounds like the exhaust rattling, it is soooooo weird. Car boosts, holds and runs really well! I have no idea what it is!
    Originally posted by Underground
    You guys are just dead inside
    Formerly 04Red_Rocket
    No Better Friend, No Worse Enemy.
    Somebody please take this piece of shit off my hands.
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    You sure someone didn't replace it with a TDI engine
    Check the belt area perhaps, maybe something got lodged in there.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Jan 28 2007
    Bay Area, Norcal
    Quote Originally Posted by gdawg'05a4 View Post
    god tell me about it! so embarrassing.
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    I had a similar sound http://youtube.com/watch?v=oIhKXCbuOCM (video upload is still processing as I write this). I first checked that I had oil in the valve cover (I did), then replaced the cam chain tensioner and the noise went away. Yours could be oil related since it goes away when you rev the engine (and more oil pressure is created).
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Jan 28 2007
    Bay Area, Norcal
    Quote Originally Posted by bananas View Post
    sound very similiar
    did you take off the valve cover? how did u check ?
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    This probably wont help AT ALL..lol but try playin with ur heatshield a little bit
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Get a piece of hose, about garden hose size and trim it to about 2 ft. long. Place one end to your ear and move the other end around the eng. until you can isolate the area it's coming from. To me it sounds like the cam chain tensioner on the back of the cyl. head has/is failing.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 28 2007
    Bay Area, Norcal
    I found a DIY for the passat AWM cam chain tensioner engines here
    http://www.passatworld.com/forums/sh...d.php?t=215732
    what differences if any should I expect for our AMB engines?
    Jun 13 2005
    Minnesota
    That's a nicely illustrated writeup. I can't think of any differences.
    Veteran Member Four Rings evil_O's Avatar
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Quote Originally Posted by GtiRSmiley View Post
    Heatshield popped into my mind as well.
    2013 Ibis White S4||P+||DSG||Sport Diff||B&O||Black-Chestnut Interior|| Unitronic Stage II+ & TCU Stage II||Luft-Technik Intake||20% Tint || KW H.A.S. Kit||TSW Bathurst ||Magnaflow res X-pipe||Copious amounts of Xpel| PIAA Plasma Ion Yellow Fogs||ECS 2-Piece Wave Rotors
    Jun 24 2008
    E46 M3
    Woodinville WA
    I would definitely take off the valve cover to check out the cam adjuster/chain tensioner. Sounds about right if one of the chan guides is broken. Seen it a few times on both 1.8T's and 2.8's. Could also be possible that the oil is not flowing through the tensioner properly anymore. As in not lubricating the chain on both the top and bottom chain guide. If one of the chain guides is broken, then make sure to inspect the chain very carefully and replace the chain as well if it has rubbed on anything metal.
    Pretty nice write on the proceedure, though, I would actually pull both cams and loosen the cam sensor shutter wheel before loosening the T-Belt so you can change the seals and plug as well. Good time to do all timing belt stuff if it hasn't been done before. Pulling both cams makes it pretty easy to change the adjuster as you can just pull both cams with the tensioner, set it all on a bench, change the adjuster and set it all back into the head. Make sure the notches line up and you get the 16 roller count correct. If you have to use the tool off the new unit to remove the old one, just make sure you remove it very carefully from the new one without droping the chain guide and reinstall it very carefully. Also make sure to use a very slight bit of silicone sealer on the end bearing caps. You'll be able to tell where when you take it off.
    C
