Results 1 to 18 of 18
    Senior Member Two Rings KryptoniK01's Avatar
    Nov 27 2006
    B5 S4
    Vancouver BC
    Anyone know where I can find a stock Y-Pipe in good condition?
    I already searched through the classifieds without any luck and also tried shokan & ebay with no success. (there are 2 on ebay but one looks damaged and the other seller didn't respond to my e-mails)
    I'm looking for a stock Y-Pipe that must be in good condition with no cracks/leaks etc. I broke the end of the fitting coming off the right side of the pipe and need a replacement.
    Thanks
    :: APR V5 :: GIAC Tip Chip :: AWE Boost Guage :: Apikol Rear Diff Mount :: 710N's ::
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Anyone know where I can find a stock Y-Pipe in good condition?
    Deb38 just sold his powdercoated one to someone, they are probably going to have a stock one...
    - Clint
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    local junk yard or parts recycler...
    i got one off ebay for $20 shipped.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Maybe time to just upgrade to the aluminum piece?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Established Member Two Rings DAP's Avatar
    Mar 16 2004
    FYI, there are two different y-pipes depending on your model year. The '00 and '01 S4s had one with the PCV connector at an angle while the '01.5 and '02 S4s had the PCV connectors straight (and a different spider hose assembly to accommodate that).
    Make sure the one you get is correct for your car.
    I have a spare '00-01 y-pipe. Its a bit scratched up but otherwise fine.
    Nov 27 2006
    B5 S4
    Vancouver BC
    Quote Originally Posted by DAP View Post
    Thanks for the info, I didn't realize there were 2 different y-pipe styles. Although my car is a 08/00 build date with old style emblems it appears it has all the 01.5 upgraded parts such as the intake manifold, y-pipe etc. Here is a photo of my current y-pipe.
    Anyone have a newer style y-pipe kickin' around?
    Account Terminated One Ring
    Jul 23 2008
    '00 b5 s4, '86 4kq
    new hampshire
    go oem rs4, email me im selling mine
    Nov 27 2006
    B5 S4
    Vancouver BC
    Quote Originally Posted by red4kq View Post
    I think the rs4 pipe is overkill for me since I'm not stage 3. But if you want to sell it to me for like $80 I'm in
    Account Terminated Two Rings wreckedimolas4's Avatar
    Jun 11 2008
    silver b5 stg 2+ 95 m3
    almont
    i will sell my stock one for $80 shipped
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Is the RS4 y a little bigger or something? Does it really make that big of a difference?
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Aug 18 2007
    Ohio
    Quote Originally Posted by alias747 View Post
    I think it gets rid of the TBB, not 100% though.
    2002 TT Silver 225
    Nov 27 2006
    B5 S4
    Vancouver BC
    Quote Originally Posted by wreckedimolas4 View Post
    pm sent
    The RS4 Y-Pipe is a little larger but I don't think it's going to make a dramatic difference as the turbo inlet pipes are still the same size.
    Active Member Four Rings
    Dec 11 2006
    Boston
    you guys realize the tbb and the y-pipe don't even connect. the tbb connects to the throttle body, hence the name of the boot. the y-pipe connects to the upper intake hoses/turbo inlet piping.
    the rs4 y-pipe is slightly larger and fairly useless for the $800 price tag.
    Stage 3+ RS6's
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    I'll sell you mine, PM me
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    dude $50 shipped for a black one
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by deb38 View Post
    Yes I knew what I was talking about, I don't know what yella was thinking. lol Thanks for clearing that up though.
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    he meant the y-pipe as in the Bi-pipe. RS4 one has a metal TBB and is often called/named y-pipe, when it should be bi-pipe or OEM RS4 TBB.
    Aug 18 2007
    Ohio
    Ahh, I guess i was mistaken as i was thinking it was the pipes on top of the engine that eliminated the TBB if you went RS4.
    2002 TT Silver 225
