Results 1 to 12 of 12
    Jun 14 2007
    2000 S4
    Connecticut
    Can Jump-starting a dead battery take some life out of mine??
    I had to jump a car at work yesterday, a brand new Lexus hybrid L6 whatever the hell it was. The long car. ANYWAYS. I've noticed since I jumped it my car takes a second longer like the crank is longer to turn the engine over. Could I of effed up my battery jumping his dead battery?
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Re: Can Jump-starting a dead battery take some life out of mine??
    I'd say it's highly unlikely.
    Your alternator should bring your battery back to a healthy level if his car took a toll on it after some driving.
    If not, perhaps your own battery is getting old or you could confirm your volt gauge is in the 12V area when turned off (1-2 keyturns forward) and 13.8-14.2V-ish when running to triple-check alternator.
    But yeah, i'd say you should be fine unless the Lexus uses some special/non-12V battery etc.
    Brilliant Black 2001 S4 - 6MT <3
    Jun 14 2007
    2000 S4
    Connecticut
    when my car is off and i put it into the on pos. its higher than 12... like 13-14 ? maybe i ll take VAG out and check!
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    your fine, 13-14 is perfect
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Mar 01 2008
    Toronto, ON, Canada
    A little higher than 12V without the car started is fine, although if it really is 13-14V when turned off that seems a little high to me.
    Maybe double-check the number/gauge...or drive some and see if everything balances out.
    I wouldn't be too worried.
    Jun 15 2007
    its perfectly fine, mine sits at 14, always has and never had an issue, mike, when jumping a car you will lose a bit of power, then your alternator will rejuice it no problem when your car is running it should come back to the 13-14 whre it sits right in the middle of the cluster..mike your paranoid like always freakin rich greenwich kids lol
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Jun 14 2007
    2000 S4
    Connecticut
    lol... well i think what the problem was that this isnt any type of car i jumped... the battery itself on the Lexus Hybrid was a normal looking battery but then on the positive terminal there was a huge thing on it with a fuse in it and i think that ran the hybrid batteries as well... so the car pulled a lot from mine to start the hybrid up i think thats what the problem was
    Jun 14 2007
    2000 S4
    Connecticut
    so my battery when car is off is hovering between 11.680 and 12.760
    Registered Member Two Rings vladbe's Avatar
    Jun 16 2004
    2002 Audi S4 casa white
    Washington
    You shouldnt jump start cars.
    2002 S4 Casablanca White
    2000 540i 6 spd
    Jun 14 2007
    2000 S4
    Connecticut
    lol well, im going to just buy a new battery. i've kinda wanted to get it out of the way for a while so i ordered one its going to be here tomorrow.... i dont have my radio code THIS is gonna be fun LOL
    Oct 31 2005
    Ashburn
    I don'y get why my car has no problems with this(RADIO CODE) i've changed my battery or left the car battery disconnected for days and never had an issue with the radio.
    - Instagram: @Sinister_rs5-
    Mar 01 2008
    Toronto, ON, Canada
    Unless the gauge is quickly sweeping back and forth or something, that's exactly where it should be when the car is off.
    Never hurts to replace an old battery and everything, in fact i'd advise it after 4-5 years as maintenance, but I don't think you "killed" your battery or anything from jumping this guy.
