Results 1 to 2 of 2
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Coolant Leak??? Pics Included...
    Sorry for the bad pics, pictures were taken from under the car looking up from the oil filter. The black pump looking thing with the writing on it is leaking fluid. From the top of the engine the hose is running from the coolant tank to this thing? What is it and any write ups on how to replace it?
    [IMG][/IMG]
    Also, my differential output shaft seal is leaking...what fluid is this? and where can I check the level of the fluid and how do I add the fluid? Thanks!
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Re: Coolant Leak??? Pics Included...
    I'd guess your secondary water pump. AW has a writeup. I have to do mine as well.
