Results 1 to 11 of 11
    Established Member Two Rings thomas33's Avatar
    Dec 04 2007
    Salt Lake City
    TCM is going out Flashing Gears.. Need Help $1300 from Dealer
    B7 A4 FWD 2.0T No more warranty left.
    My TCM is going out. Getting the flashing gears more and more commonly now. I understand the part is over $1300 dollars from dealer before install. Does anyone here have experience with other alternative options other then the dealer $1300 dollar option?
    Looking for a less expensive route to replace the Transmission Control Module other then the dealer $1300 option.
    DUH! an Audi
    los angeles, CA
    Re: TCM is going out Flashing Gears.. Need Help $1300 from Dealer
    try finding it used, what are your specs I can ask a junk yard i know
    Dec 04 2007
    Salt Lake City
    Thanks Quattro,
    I have a 2006, A4 2.0 Turbo FWD Automatic S-Line
    Let me know if you can help, I would be grateful.
    Jan 01 2008
    Long Island NY
    convert that sucker to a 6 speed.
    Jan 01 2008
    Long Island NY
    make sure you specify CVT and not just automatic.
    Jun 30 2012
    BC
    I have the same problem, PRNDS light is flashing more and more frequently. When I start to drive the car doesn't always take off smoothly and just yesterday I went into an artificial "neutral" and wouldn't deliver power to the wheels until I had slowed down. I checked out this site too ECU Testing Ltd. Looks like an affordable alternative if you can wait to have the TCU rebuilt.
    Senior Member Two Rings djsp00kyk's Avatar
    Jul 25 2009
    B9 Sq5, B7 A4, 2.5l swapped NC miata, LS swapped Jeep TJ
    Mississippi
    Quote Originally Posted by thomas33 View Post
    If your CVT is will cost about $1700 to get it replaced at the dealer. You cant buy used cause no scrap yard is going to ruin a good tranny, busting it open, to get the TCM out to sell it. Good luck...just bite the bullet and take it to the dealer!
    Junior Member One Ring
    Nov 21 2009
    FL
    old thread, but check out cvtsettlement.com to those who paid out. You may be able to get re-imbursment.
    Mar 24 2013
    Oakdale, CT
    Trade it in on a MT car before the CVT takes a dump on you. I'm only partially joking... I haven't heard a single good thing about CVT. It's all been nothing but horror stories.
    Edit: I fell prey to the necro'd thread again...
    -Adam
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Thanks Quattro,
    Is it CVT? If so how many miles on the car bro?
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Established Member Two Rings ssantos0011's Avatar
    Jun 21 2012
    Bluffton, SC
    Same thing happened to me about a month ago when I took it to the dealership to get extended warranty repair done after i picked up the car the PRNDS started flashing so i told them and they felt bad so they gave me 50% discount so it came out to about 650 for me, good luck
