Results 1 to 2 of 2
    Registered Member Two Rings audiRSallroad's Avatar
    Jun 19 2008
    2001 allroad
    H-Sport Anti-Sway Bar Install, Help!
    I'm going to attempt to install the sway bar on my '01 allroad, does anyone know if the installation process would be the same as on an A6? I was going to use this guide for installation, http://forums.audiworld.com/a6/msgs/493098.phtml
    any help is appreciated
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    Re: H-Sport Anti-Sway Bar Install, Help!
    That's the one I used for my install. Make sure you get the stickers facing the right direction. The biggest source of complaints with H-Sport is from bushings pulled through/damaged from mis-installation.
