Results 1 to 16 of 16
    Veteran Member Three Rings Brooksthepro's Avatar
    Apr 29 2005
    2001 Audi a4, loud ass gocart!
    Santa Barbara, Ca
    hardwire radar detector
    hey guys, i just picked up a radar detector and i want to hardwire it. I know the easiest way to do this is to hook it up to the 75x under the dash. But i want to have the detector High up by the rear view mirror. Some of my buddys with other cars (not audis) have been able to hook it up via the dome lights or moon roof power in the roof.
    so my question is, is there any way to do this in our car? im sure there is but i dont have a volt meter handy so i cant test for power up there. does anyone got pics i can see of an install?
    TIA!!
    GIAC FXK04/Gen380cc/TTMAF/FMIC/custom magnaflow/710n/Labree HFC/034 Highflow Exhaust Mani/17"Team Dynamics ProRace1/CAI/race springs/Rs4 Grille/VDO vent boost gauge/SS brake lines/x-drilled rotors/12in Infinity /600w Infinity amp
    SANTA BARBARA LOCALS!! SBEUROCLUB
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Re: hardwire radar detector
    I did mine - there is a constant power source in the sunroof control. I had to probe around with a multimeter until I found it. Works perfectly - the only thing is that it is constant power so sometimes I forget to turn my radar detector off...
    Of course things could be a little different on a 2001 - mine is a 1998.
    Oct 25 2006
    Oxford, CT
    Jeez - it would help if I read your post. I don't have any pictures and I didn't read that you don't have a voltmeter...hmmm....
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    There are DIYs all over. I just tapped into a fuse line
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    just run the wire from the 75x to the detector that is what i did
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Oct 25 2006
    Oxford, CT
    The point is - if you have a volt meter you can avoid running a wire all the way up to where you want to go. My hard-wire cable is only 8 inches long.
    Apr 29 2005
    Santa Barbara, Ca
    hmmmmmmmmm i guess im gonna have to see if i can borrow someones volt meter. what did you guys do for a fuse? rigged up one on the cable to the detector? or just tapped the wire and hope the fuse its connected to somewhere is good enough?
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    tap 75x and run the wire up the pillar
    i tried the sun roof, only "constant" power which sucked.
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Quote Originally Posted by JaVa View Post
    X2, You can hide the wire behind trim and stuff.
    Jun 04 2007
    Austin/DFW, TX
    there are a couple diys online for hardwiring it to the sunroof thing. It's easier just to use a t tap
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Two Rings sleeprr's Avatar
    Jul 05 2008
    94 90 sedan, 95 318TI....wifes
    Coeur D'Alene, Idaho
    if you have a mirror with the compass you can tap into the white wire on the plug (mirror side of the plug) and it's not constant, just hot with the key which is perfect :D
    Apr 29 2005
    Santa Barbara, Ca
    Quote Originally Posted by sleeprr View Post
    ya i have it, any pictures by any chance??
    edit: i dont have the compass but i have auto dimming? will that work?
    Jul 05 2008
    no pics but if you just take off the cover you will see the plug and the 6 wires I'm talking about. Not sure if the auto dimming will have it but it's gotta have some sort of power.
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    The auto dim and compass mirrors use the same wirring.
    There is also a switched lead that runs into the sunroof control module...
    Go to an auto parts store and pick up a test light for under $10... great thing to have!
    For the other posters... whats the 75x?
    Jul 05 2008
    test lights good for hot and cold but a voltmeter/multimeter would be better to assure that whatever your hooking up is able to be suppored by the wires you're tapping into.
    Jan 07 2007
    Quote Originally Posted by Jared71482 View Post
    75X is a power post under the drivers knee bolster, next to the relays, it is switched with the key.
