Results 1 to 6 of 6
    Jan 26 2008
    Sydney
    C5 Turbo Timer Install
    Hi,
    Has anyone installed a turbo timer on their C5 A6 that works with the factory immobiliser?
    Veteran Member Three Rings chrisbostonusmc's Avatar
    Jan 12 2008
    Sarasota,Fl
    Re: C5 Turbo Timer Install
    Im interested in this as well
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    i thought turbo timers on these motors were a bit of a waste? dont we have an auxiliary water pump or something that turns on after the cars off?
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    Quote Originally Posted by audirs View Post
    that's what i was told as well.... anyone got facts to back this up??
    Established Member Two Rings EnviedA6's Avatar
    May 06 2008
    Minneapolis, MN
    The information can be found in your owners manual. As for the turbo timer, you can install one with the immobilizer. You would just splice and connect the ignition wire from the Turbo timer to the wire located underneath the steering column cover. It's sort of hard to explain but if you have the electrical diagram for the car you should be able to install it.
    Envied A6
    2001 Silver Audi A6 2.7T Tiptronic, APR Stage 2 chip, Blitz custom intake, Dynomax Turbo custom exhaust, Custom down pipes, Turbosmart MBC, Carbon Fiber interior trim, arm rest, engine cover, air box cover, hood,trunk, mirrors, B pillars, eyebrows,Tinted tails & side markers, H&R lowering springs, H&R 5mm and 10mm wheel spacers, 19x9 Konig Next wheels, 245/35/19 Toyo Proxeys 4
    Veteran Member Three Rings sempaipaul's Avatar
    Dec 21 2007
    several Porsches
    Gaithersburg MD
    anywhere i could find one of those diagrams?? :)
    -Paul
    Garage: 03' RS6 (FOR SALE); 16' 328i xDrive Wagon (FOR SALE); 13' X3 M-Sport; 05' Cayenne Turbo, 01' 911 Turbo
