I've been having a rough idle without any CEL's and I've tried chasing it down as I've described in this previous thread and have not solved the problem:
http://www.audizine.com/forum/showthread.php?t=224859
The problem started soon after i replaced the 90 elbow tube on the hose of the secondary air inlet up top by the injectors. As well as the quick connecto hose to the secondary air injection pumpmotor.
After researching a bit more I think the rough idle is related to the Charge pressure regulation system. I've already had some check valves, recirculatin valve (710N) and some hoses replaced under normal maintenance conditions. I know the N75 (wastegate/bypass regulator) hasn't been replaced, neither has the pressure regulating valve,or the combination valve for the secondary air injetion.
I've also checked out the link below and I'm thinking about replacing the breather valve.
http://www.passatworld.com/forums/sh...d.php?t=196909
Basically, I don't know where to start any suggestions woudl be appreciated.
