Results 1 to 8 of 8
    Established Member Two Rings Dcting's Avatar
    Mar 25 2008
    Forest Hills, NY
    How much would it cost??...
    Just wondering how much it would cost to install the OEM RNS-E Nav system in my car? I know if I go to the dealership its based on the hourly rate, so how many hours would be needed to have this install done? Im really contemplating picking up a system and all the parts from navparts...
    Any help would be greatly appreciated...
    Thanks.
    -DT
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Re: How much would it cost??...
    If you have a little bit of technical know-how, you could easily install a nav unit in an afternoon, or even a couple hours. A friend and I recent installed an aftermarket nav unit, 9 speakers, an amp, and two subs in about 5 hours.
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    RNS-E is pretty straight forward. hardest part is mounting the antenna for the GPS.
    Active Member Two Rings vedran's Avatar
    Jun 25 2008
    Norway
    Quote Originally Posted by Dcting View Post
    Thanks.
    -DT
    What radio did you have before, one slot or double slot radio?
    DUH! an Audi
    los angeles, CA
    If you have a double din radio AND you know how to follow directions you should be able to do it yourself.
    If you get the rns-E and have all the harnesses to make the install "plug and play" its straight forward.
    What is the website for nav forums that everyone goes to?? I think you should start there.
    Feb 09 2008
    2006 A4, 2006 4Runner
    Colorado Springs
    Seriously, just do it yourself, it's literally plug and play. You can get it done in an hour with no snags, the biggest problem being getting the old radio out. Think I paid around $1100 for mine on eBay with everything.
    Mar 25 2008
    Forest Hills, NY
    Thanks for all the comments! I think you guys have pretty much convinced me to order it and install it myself...
    The only part that I think I would need some direction in would be the running of the wires back to the antenna. How easy was this for all you guys that did it yourself? Do you have to pull apart the headliner?
    Feb 09 2008
    Colorado Springs
    Order it with a magnetic antenna and just run it behind the gauge cluster. There's a bunch of writeups on Navplus, just check em out, super easy.
