Results 1 to 8 of 8
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Wheel Spacer Problem
    Got my Ichiba 10mm wheel spacers and tried to install them with my RS4 reps. The spacer wont fit all the way into the opening of the wheel.... They fit perfect into the opening of my stock wheels, but wont fit into the RS4 reps? Is there anything I cn do to them to make it work?
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Mar 27 2005
    The Cold North
    Re: Wheel Spacer Problem
    is the problem the difference on the angle of the chamfer?
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Nov 04 2007
    Minnesota
    dont know what a chamfer is?
    Current:
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    chamfer is the angle cut on the end that slides into the wheel or angle cut on drilled holes
    Oct 22 2005
    Reppin the Mitten.
    Do you run hubcentric rings?
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    You might need to get some sandpaper and sand down the paint/powdercoat on the RS4's. It might be on there a little thick.
    -Darrick
    Nov 04 2007
    Minnesota
    Quote Originally Posted by pondside36 View Post
    Yeah its that, it wont fit all the way into the wheel
    Current:
    Mar 27 2005
    The Cold North
    Quote Originally Posted by gotboost View Post
    Then you need a spacer with a different chamfer. You may want to just look at a set of H&R Spacers. MTM & Eibach also sell spacers. If need be you can get a set custom machined.
    2020 Chevy AEV ZR2
