Results 1 to 24 of 24
    May 13 2007
    Northern VA
    Detailed: 2002 Lexus LS430 (90+ pictures)
    This black Lexus was extremely dirty, had a lot of clear coat etching, swirl marks, marring, holograms, severe buffer marks from dirty wool pads and compound (thanks to the dealership), basically every paint defect and imperfection you could think of. The car has been washed and machine polished SEVERAL times by the dealership. To top it off, whatever products they used to polish the car left silicone or some other chemical in the paint which was reacting with my polishes. This required me to do numerous chemical washes and wipe downs to remove whatever chemical was in the paint. This significantly increased buffing time.
    This first set of pictures show the condition of the exterior upon arrival.
    I polished behind the door handles by hand which gave a slight improvement. Sorry, no after pictures.
    The door pillars were polished similar to the paint. Sorry, no after pictures.
    This next set of pictures shows the lovely work done by the dealership. The imperfections left over by them include swirl marks, marring, holograms, severe buffer marks from dirty wool pads and compound, etc.
    There was polish residue in all the emblems and just about every crack around the car.
    The wheels, tires, and wheel wells always get cleaned first. The wheel wells and tires were cleaned with a degreaser. The wheels were cleaned with a dedicated wheel cleaner which is safe for all wheels.
    - Dan
    May 13 2007
    Northern VA
    Re: Detailed: 2002 Lexus LS430 (90+ pictures)
    As I mentioned before, the car had been cleaned and buffed by the dealership. This is an automatic red flag for us. Not because the condition many dealerships and body shops leave the paint in, but because of the chemicals that can be left in the paint. Therefore, the paint was soaked with a paint degreaser in hopes of removing some of these chemicals. Unfortunately, this wasnt enough and the paint needed several alcohol and prep sol wipe downs.
    Here are a couple pieces of clay after claying the paint.
    Now, onto the polishing process!
    Step 1 of the 3 step polishing process is Defect Removal. The paint required heavy compounding with wool pads on the rotary.
    Before
    After step 1 As you can see, there is some hazy from the compound and wool pad. This will be completely removed during the next step of polishing.
    After heavy compounding with a wool pad the car becomes very dusty. Therefore, the car had to be rewashed when compounding was completed.
    Step 2 of the 3 step polishing process is Gloss Enhancement. This is when we remove any left over haze from step 1 and restore the gloss. We get the paint as close to LSP ready as possible (no holograms, buffer marks, etc.). Many detailers will stop at this point, but there is still more gloss to be had and we go after every little bit!
    Here is a picture taken after completing step 1 of the polishing process. Again, you can see some left over haze from the compound and wool pad.
    Here is the same spot after step 2 of the polishing process.
    During the polishing process, the paint is cleaned with alcohol and or prep sol to reveal the true condition of the paint. Once the process is completed and we are satisfied with the results, we bring the car outside and inspect it under direct sunlight.
    If we feel the process is completed, then we rewash the car again to remove all polish dust, and prepare it for wax or sealant.
    And here are the final results.
    Next up is the interior. The interior on this car was decent at best. The leather was extremely dirty, along with the carpet mats. The interior carpet needed a thorough vacuuming and some minor stains needed to be taken care of. All interior surfaces needed a very thorough cleaning as well.
    All of the leather was vacuumed and cleaned with a dedicated water based leather cleaner and a soft foam sponge.
    Here is a 50/50 shot of the drivers seat. The bottom half has been cleaned while the upper half is untouched.
    Here is a picture of the back seats, you can actually see the dirty coming off the leather.
    - Dan
    May 13 2007
    Northern VA
    ALL of the interior surfaces were cleaned using several different brushes, microfiber towels, and a dedicated interior cleaner which is safe for all surfaces.
    The windows were cleaned using a dedicated window cleaner and microfiber towel that doesnt leave lint. We made sure to roll the windows down to get the very top of the windows.
    All of the plastic wood trim was cleaned, polished, and protected.
    The carpet mats were cleaned using several different carpet cleaners, brushes, and a hot water extractor.
    Here is the water from the extractor after cleaning only the carpet mats.
    - Dan
    May 13 2007
    Northern VA
    The interior was thoroughly vacuumed, spot treated, and extracted.
    Here is the water from the extractor after cleaning only the interior carpet.
    And here is the final result after completing the interior.
    - Dan
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    wow!! you really know your stuff. If i lived back east i'd have you do my car for sure. Great pictures and very thorough documentation.
    {99.5 Avant}
    May 13 2007
    Northern VA
    Quote Originally Posted by Jibberific View Post
    Thanks a lot, I appreciate that!
    - Dan
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Wow! Fantastic job!
    2 questions, out of curiosity:
    How long did that take?
    How much does a detail like that cost?
    May 13 2007
    Northern VA
    Thank you! I spent about 20+ hours on the exterior and about 8 or so on the interior. $$$$$$$$$
    - Dan
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    nice work nice write up.
    looks like the leather master products did very well on this job.
    May 13 2007
    Northern VA
    Quote Originally Posted by phil@detailersdomain View Post
    How could ya tell?
    Thanks for being such an awesome supplier, what would we do without you!?
    - Dan
    Feb 24 2004
    they way you applied it and the bottle in the picture, as well its the best stuff out there for leather so I figured why would you use anything else. look at it pull all that dirt off the leather.... :)
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    awesome work!
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Sep 19 2007
    Erie, PA
    04audiA4 - Wow - fantastic job....
    pw-man
    My Garage:
    2007 A4 Cab 3.2 Dolphin Gray Metallic (Audio, Convenience, Heated Seats, Bluetooth)
    2007 Q7 3.6 Premium Cobalt Blue Metallic (Infotainment, Technology, Panorama, 20", Convenience, 3rd row, Invision Rev III)
    old stuff (read gone):
    2005 Acura MDX, 2003 Audi A4 2.0T, 1996 Infiniti I30, 1993 Infiniti G20
    May 13 2007
    Northern VA
    Thanks a lot guys.
    - Dan
    Jul 23 2008
    Pasadena & San Diego
    wow amazing work. nice job editing photos too. What were the products used? I'm guessing....
    M105
    Menz SIP
    Menz 106ff
    1Z cockpit
    Did i guess right on any of them?
    May 13 2007
    Northern VA
    Correct. 1z was used, but thats not what you see in the pictures.
    - Dan
    Senior Member Two Rings 97ss10's Avatar
    Jul 24 2008
    2003 A4 Quattro 3.0 / 2005 Nissan Frontier NISMO
    Louisiana
    A-FREAKIN-MAZING!!! This even motivates me to want to go detail my car like this in the parking lot...or just find a good detailer cause that's A LOT of work! Great job!
    May 13 2007
    Northern VA
    Quote Originally Posted by 97ss10 View Post
    Thank you!
    - Dan
    Senior Member Two Rings gervi's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    Thats some amazing work... it really shows your attentiveness to every aspect of the car... The owner of that car must of been very surprised to see the final result, as compared to what you had to start off with.
    May 13 2007
    Northern VA
    Quote Originally Posted by gervi View Post
    Thanks a lot, I appreciate it!
    - Dan
    Veteran Member Three Rings casuso's Avatar
    Sep 19 2006
    Mexico
    Can you tell us about the products you used?
    Some of us try to learn from you guys, but we need info about what a pro does ans uses.
    May 13 2007
    Northern VA
    Quote Originally Posted by casuso View Post
    Feel free to shoot me a PM.
    - Dan
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    amazing!
    Veteran Member Three Rings dchan189's Avatar
    Jul 20 2008
    2004 Audi a4 1.8T Quattro USP
    San Diego
    how much did the dude pay you? or how much does that cost? haha
