Results 1 to 40 of 43
    Jul 26 2008
    Quakertown PA
    What's the max wheel width for a C5 A6?
    Hi everyone,
    First of all, this is a great forum. I was wondering what the maximum wheel width for a 2000 A6 2.7t is? Can 9.5" wide wheels fit without rolling the fenders? If so, what offset is required and what tires size works? I saw a picture of an A6 with Axis Penta wheels that I guess were 19x9.5 and had a 40mm offset. Do those fit? What about the 25mm or 30mm offset ones?
    Does anyone have pics of 9.5" wide wheels on their car??
    Thanks in advance!
    Alex
    Registered Member Three Rings m-avant's Avatar
    Aug 05 2007
    cars with wheels...
    Californication
    Re: What's the max wheel width for a C5 A6?
    I have 20x9.5 rears on my Avant, ET40 offset - no fender mods. I haven't tried to fit them on the front wheel wells yet. My fronts are 8.5, and they cleared OK with stock suspension - rubbed a bit with Eibachs.
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    old Avant (missed dearly) :2000 A4
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    i have 18x9 all 4 wheels, eibach lowered and no rubbing at all, ever.
    2004 Audi A6 2.7T
    Junior Member Two Rings
    Jul 28 2008
    Quakertown, PA
    I am looking to upgrade my A6 2.7T wheels. I have it lowered via H&R Sports (~1.5"?) I currently have AT Italia Spyder, 18x8.5 with a 35mm offset, 235x40s
    18x8.5 Compared to OEM:
    • 0.36" further penetration into the wheel well
    • 1.14" further out (wider)
    • 0.4% > wheel diameter
    I was wondering if Axis Penta 19x9.5s shod with 235x35 will work all the way around?
    with a 40mm offset:
    • 1.05" further penetration into the wheel well
    • 1.45" further out (wider)
    with a 25mm offset:
    • 0.46" further penetration into the wheel well
    • 2.04" further out (wider)
    So, does anyone know if 19x9.5" wheels (and the offsets) work on all four corners? And if there were any issues with rubbing?
    I know that 19x8.5 is probably safe... Just seeing if I could push the envelope with 9.5-inch wide tires on the front.
    I have also seen staggered setups offered:
    • Fronts: 19x8.5 235x35x19
    • Rears: 19x9.5 275x30x19
    The wheel diameters are the same, so the differentials shouldn't care.
    Thanks in advance!
    Established Member Two Rings EnviedA6's Avatar
    May 06 2008
    Minneapolis, MN
    I have 19x9.5 Konig Next wheels wrapped in 245/35/19 tires. Using 8mm H&R wheels spacers in the front and 10mm in the back with no problems, it's also lowered but everything rides smooth
    Envied A6
    2001 Silver Audi A6 2.7T Tiptronic, APR Stage 2 chip, Blitz custom intake, Dynomax Turbo custom exhaust, Custom down pipes, Turbosmart MBC, Carbon Fiber interior trim, arm rest, engine cover, air box cover, hood,trunk, mirrors, B pillars, eyebrows,Tinted tails & side markers, H&R lowering springs, H&R 5mm and 10mm wheel spacers, 19x9 Konig Next wheels, 245/35/19 Toyo Proxeys 4
    Jul 28 2008
    Quakertown, PA
    sweet. do you know the offsets of your wheels?
    May 06 2008
    Minneapolis, MN
    I'll pull my wheels off this weekend and see. I know it's in the 30's because my stock BBS's are 43.
    Envied A6
    Jul 28 2008
    Quakertown, PA
    wow, that would be a big help. maybe 35-ish? the offset is a real key for my purchase so that i can get a proper fitment. which is what you obviously have!!
    i looked all over the web for the offset for Koenig's Privat Netz (I assume that is what you meant).
    my calcs were to compare against my OEM 16x7s with a 45...
    my 18x8.5 AT Italias run 35mm offset, yielding 0.36" further inward towards suspension, and 1.14" sticking out of wheel well more.
    for 9.5" wide rims, offsets yield in/out depth as follows:
    25mm: 0.46 in, 2.04 out
    35mm: 0.86 in, 1.64 out
    40mm: 1.05 in, 1.45 out
    So, your number will help me immensely!
    Thanks! Can't wait.
    Jul 26 2008
    Quakertown PA
    bump
    what 9" wide offset works?
    Mar 30 2008
    Pittsburgh
    35
    2004 Audi A6 2.7T
    Jan 01 2008
    Long Island NY
    You can fit 19x12 on a 4.2.
    Jul 26 2008
    Quakertown PA
    Any year to year offset difference within the C5 chassis?
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Frank - you have Pro-kit or sport Eibachs?
    I'm contemplating 18x8.5, 235/40, and clearly need to lower car. I see Cupra on your signature now -- what, no pics?
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Jul 28 2008
    Quakertown, PA
    here is my lowered A6. 18x8s ET35, 235x40. I went with H&R sport and bilstein shocks.
    FWIW: For this wheel, my calculations show a 0.11 inch backspace (further towards hub) compared to OEM.
    With 8.5 width, you get the following backspace for the given offsets:
    ET30 --> 0.16
    ET35 --> 0.36
    ET38 --> 0.48
    Apr 01 2008
    2010 Jetta TDI
    can we try larger photo Jonny? I'm looking at Eibachs (pro? sport?) and H&R (sport?), trying to figure clearances if I go to 235/40/18 (or stay with my225/35/17s). Pro-kit vs. Sport seems to be about 3/4"?
    current set up (I know, like a jeep....)
    http://www.audizine.com/gallery/show...8&ppuser=27141
    Mar 30 2008
    Pittsburgh
    Quote Originally Posted by wofman View Post
    Nah its not on yet, im going to get my bumper repainted first, but its on koni fsd + eibach springs. :)
    2004 Audi A6 2.7T
    Apr 01 2008
    2010 Jetta TDI
    but which springs?
    May 06 2008
    Minneapolis, MN
    The wheels are a 38mm offset. Wheels are Konig Next (wheels are discontinued) but yes they are 19x9.5
    Envied A6
    Jul 28 2008
    Quakertown, PA
    did you click on the image? you will see a larger photo :-)
    also, memory is dim, but i have H&R Sport Springs and I think Bilstein Sport shocks. (That is, i think both shocks and springs are "Sport". I know I bought Sport... just forget if it was a moniker for both or not).
    It lowered the car somewhere around 1.5" to 1.75" I believe. No issues with 18x8ET35 235x40ZR18s. Just issues with clearing dorky speed bumps now and then.
    I also have pics of inside the wheel well near the suspension bits, if you need them...
    Apr 01 2008
    2010 Jetta TDI
    Gorgeous 2000 -- great condition. I thought I clicked on pic ... obviously not very well until this time. I'll PM as well to compare some notes, eg, 18x8 vs 18x8.5. Also - lived near Q-town for 5 years, but that's going back a ways.
    What do you think about dropping to this level, boys? If I understand "sport" is a bit lower than Pro-kit (for Eibach). Is "sport" same for H&R springs and for Eibach? Trying to decide between Pro-kit and either H&R or Eibach "sport" if anybody can shed light on that. I was also looking to go with Bilstein shocks (no to Koni yellows, for sure).
    wofman
    Jul 28 2008
    Quakertown, PA
    Quote Originally Posted by EnviedA6 View Post
    Thanks for checking EnviedA6!!! I saw your gallery pics. I am curious how far out beyond the fenders the wheels protrude? It doesn't look like too much from the pics, but there were no shallow angle shots to tell how wide the tires were beyond the body.
    My 18x8ET35 is 0.1" further in and 0.9" further out than OEM.
    Your 19x9.5ET38 must be 1" further in and 1.5" further out than OEM.
    I put my hand behind my wheels, hard to imagine I could move the inside wheel edge 0.8" closer to the hub/suspension. But you seem to be rolling proof that there is no rubbing, eh?
    Are you running lowered suspension or stock? Your pics seem to reveal stock suspension height... (I am noticeably lowered )
    Thanks again for checking and posting!
    -- jon
    Apr 01 2008
    2010 Jetta TDI
    Jonny -- check PMs.
    Active Member Four Rings HOFFY11's Avatar
    Aug 01 2008
    Audi A6 4.2L Quattro
    forked river, NJ
    Quote Originally Posted by Auditude2.0T View Post
    lmao..is that serious? if not im pretty stupid for even considering it
    May 06 2008
    Minneapolis, MN
    Actually they are a 35mm offset. The car is lowered with H&R springs. No rubbing besides slight slopes when driving on the highway but not noticable. I'm out a lot further than the stock wheels so an inch and a half is a good estimate.
    Envied A6
    Nov 19 2005
    Pair of (. )( .)
    you can fit 19x10.5 on the back of the c5 2.7t for sure, i have 9.5 and 1 inch spacer with 245 tire and lowered, very little rub when 2 people on the back and very bad road....so i think i can max out 11 wide with the right offset and tire, depends what look you trying to get....and yes 19x12 will work on the c5 4.2 for sure.
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Jul 28 2008
    Quakertown, PA
    I'll have to post some pics... But I ended up going with Complete Custom Wheel C14 18x9
    My rear bilstein/K&R suspension mysteriously "settled" about 0.75"
    -- jon
    Veteran Member Three Rings 4point2's Avatar
    Oct 18 2008
    B7 S4 Avant, KTM RC390
    Vancouver, BC
    Quote Originally Posted by kievskiy View Post
    Anyone have pics of a 12" rim on a 4.2? looking into new rims too, that sounds really interesting
    Veteran Member Three Rings streetsoffire's Avatar
    Jan 04 2007
    North Jersey/Hawaii
    +1
    Die Perfekte Verbindung Aus Sportlichkeit Und Asthetik
    C5 S6
    Street
    http://i47.tinypic.com/974oj5.jpg
    Jul 28 2008
    Quakertown, PA
    Well, I think I will need to roll my C5 2.7T rims a tad...
    I am also going to switch from H&R Sport Springs/Bilstein Sport shocks to PSS9 Coil Overs. (In case anyone wants to buy my Sport shock/spring combo .)
    -- jon
    Registered Member Four Rings cerfus's Avatar
    Oct 16 2007
    Germans
    Scottsdale
    I'm running 19x9F 19x11R no pictures until my build is done.
    ///Mcars
    looking for a sileighty..
    E39 M5 DD full Hamann exhaust h-back/ Hamann CF splitter/ Hamann C Diffuser/K&N intakes/ecu tune more to come.
    Keep your eyes peeled DG, CRFS coming your way!
    Veteran Member Three Rings chrisbostonusmc's Avatar
    Jan 12 2008
    Sarasota,Fl
    yeah i have seen lambo rims on an A6 before and they're 11s
    Stage 3 SSP Tuned RS4 K04'd
    12.4 @ 115 on pump gas only
    425AWHP/467AWTQ
    ALL MY MODS DONT FIT IN SIG! DAMMNITTT!
    95 Toyota Supra T51R 800hp
    Veteran Member Four Rings A4edwin's Avatar
    Dec 07 2008
    01 a6 4.2 sport, 92vw cabriolet, 03 Tahoe, 03 Ford Explorer sport.
    New York
    +2
    Veteran Member Four Rings A6.S-line's Avatar
    Nov 29 2008
    NYC and NJ
    Quote Originally Posted by FrankA6 View Post
    Hey Frank do you remember what tire you ran on the 18x9s? 235/40 or 245/40 or 245/35?
    Jul 28 2008
    Quakertown, PA
    Last summer, I was finally able to get my fenders "flared" by Area 1320 (Easton, PA).
    Here is a photo of my 2000 A6 2.7T with freshly powder-coated 18x8s (from Complete Custom Wheel) with freshly re-mounted Direzzas (I didn't clean off the tire mounting goop before snapping this photo).
    I was able to do Track Day at Pocono Raceway, and have done autocrosses... No rubbing :-)
    -- jon
    Apr 01 2008
    2010 Jetta TDI
    Jake -- fix your computer. Your clock seems to be off a year or so!
    (he ran 235/40s)
    Dec 07 2008
    New York
    Anything wider than 9.5 expect to spent some coin on them
    Veteran Member Four Rings 2001A6's Avatar
    Sep 17 2008
    Stuff
    St. Charles, MO.
    I will be running 19x8.5 et25 front and a 19x9.5 et28 in the back this sumer...
    ~Matt.
    - PES Supercharged 01 A6 2.8Q
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Nov 29 2008
    NYC and NJ
    (he ran 235/40s)
    Search FTW! PS: aren't 235s stretched a little on 9s?
    Sep 17 2008
    Stuff
    St. Charles, MO.
    Yeah 235s on a 9" will have some slight stretch.
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Senior Member Two Rings ACHAHockey's Avatar
    Aug 17 2009
    996 911 turbo
    Buffalo, NY
    I had 18x9 Borbets with 255/35/18s and no rubbing. I have VMRs now, and will run a 265 this summer. no fender mods at all.
    2000 A6 4.2 - 18x9.5 Raderwerks, 275/35s, Vibrant mufflers, H&R coilovers, 25mm spacers in rear - 15 mm in front, Pioneer P2300 in-dash.
    2002 911 turbo - custom "straight" exhaust, PSS10s, GT2 control arms, GT2 clutch/plate/slave, bigger DVs.
    2007 STi shit box - too much to list.
