Results 1 to 9 of 9
    Junior Member Two Rings Racemagicr1's Avatar
    Feb 18 2008
    Tampa
    996 caliper fitment and parts question
    Hi i just picked up a used set of porsche 996 front and back calipers. what do i need to get to mount them on to a 2004 audi 1.8t i have nothing so far just the 4 calipers they are off 2001 996. thanks oh how much difference am i going to feel with them? they are 4 piston.
    2004 Audi A4 USP 1.8T
    Dec 25 2004
    Earth
    Re: 996 caliper fitment and parts question
    You will need custom caliper mounting brackets(5).
    Depending on the rotors you select, custom brake rotor hats(1).
    These two items adapt the calipers and rotors to your car.
    Also custom brake lines(4).
    IMO, your better off getting a BBK, where all these factors have already been engineered, and fabricated for your specific make
    and model of car. As "custom" brake parts are generally very expensive to procure.
    Dec 25 2004
    Earth
    Here's my latest brake upgrade-
    B7 S4 brakes. Cost me less than $700, and are 345mm rotors.
    Soon to have these-
    B7 RS4 brakes. 365mm rotors, 8-piston Brembo calipers, and all these bolt right onto the B6 A4!
    The caliper brakets and rotor hats have already been engineered and everything just needs to be bolted on! Can be DIY installed in less than 2 hours!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Nice! How do you plan to get your hands on a set of those [MikTip]?
    -Sami-
    Feb 18 2008
    Tampa
    ok i should probably get rid of them then but where can i get a hold of some s4 or rs4 calipers and parts needed to do the brake job oh do the rear calipers fit on as well or is it just the front that bolts up.
    Dec 25 2004
    Earth
    My B7 S4 front brakes will be forsale after I install the B7 RS4 brakes.
    Feb 18 2008
    Tampa
    let me know send me a pm with price and all
    Dec 25 2004
    Earth
    A gentleman who upgraded his B7 RS4 to Alcon's, sold me his OEM B7 RS4 brakes. Simply awaiting UPS to deliver'm
    Dec 25 2004
    Earth
    Quote Originally Posted by Racemagicr1 View Post
    Will do!
    The larger rear OEM B6 S4 brakes bolt up to the B6 A4
