Results 1 to 11 of 11
    Senior Member Two Rings galvan11's Avatar
    Aug 20 2007
    02 pearl gt s4, vw passat, 06 cbr
    south
    timing belt diy question
    Is it necessary to remove the cam lock plug? Some set of instructions say so, and others dont? I cant seem to find it on the other hand!
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: timing belt diy question
    Quote Originally Posted by galvan11 View Post
    Honestly, I would think that lining up all timing marks should do it without any tool... But thats just me
    So, the answer is, if the timing stays on, it stays on
    - Clint
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Please don't assume timing is good. You don't need to pull out the cam plugs but you definitely need a cam lock bar and a pulley puller to get your timing to be 100% on.
    How do I know? I've done probably 7-8 of them now.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    I 2nd the cam lock bar. If your experienced then you dont need it but its somthing to have for sure.
    As far as using the cam lock pin, I didnt use it. I havent started my car but I'm pretty sure its ok. As long as you used the cam lock bar you dont have to much to worry about. the lock pin is just extra insurance
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Dec 10 2006
    Wisconsin
    Quote Originally Posted by S4 in_lowplaces View Post
    2nd half /\ his statement. You don't really need the crank lock pin so long as the tick marks line up on the plastic shield and the crank pulley. I was always using the pin until I spoke with another Audi tech who had done about 100 TB's on 2.7T's and he said he never used it. You always need the cam lock bar though. If you can't get it on, then your timing is not 100% on.
    Wings
    Carbs
    Titaniums
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    I can't count the number of V6 / V8 timing belts I've replaced.
    That includes all from run-of-the-mill V6 / V8, to (R)S4 / RS6.
    I've never used the locking bar, but that's not to say you shouldn't use it, if you're not 100% confident.
    Dec 06 2007
    Calgary, AB, Canada
    Line up the TDC mark on the crank pulley, then use the cam lock bar. You won't have any problems.
    Aug 20 2007
    south
    I ended up putting in the drain plug along with the cam lock bar.
    I installed the timing belt without removing the sprockets and hoping when I crank up the car tomorrow everything is fine.
    The reason I'm somewhat worried is due to my cam sprocket jerking to the right about 45 degrees when I was tightening the gear puller in the cam bolt. I ended up just turning it back and lining it up with the other cam. I would have taken the sprockets out if my gear puller would not of just snapped
    IS there any chances I messed up the timing?
    Jan 09 2008
    United Kingdom
    If in doubt, please don't even attempt to fire the car up, till you get it checked out by someone who knows the correct procedure / settings.
    That's the advice I give anyone who ever rings me to confirm timing issues.
    Feb 09 2006
    Huntington Beach
    Maybe but i doubt it. If it only spun 45 degrees then i would say your fine, but you could have bent a valve if you spun it any more. Ayways, there's really no way of knowing till you start the car up. But I'm pretty sure you'll be fine.
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    wont the belt tension be wrong if you dont losen the cam gears?
