Results 1 to 8 of 8
Thread: Rod question
    Q7, Q7, F-type manual
    Rod question
    Can any of you guys with the stock rods out of your motor take a couple of up close pictures for me with a ruler along the length of the rod and across the rod for scale? Also, what is the wrist pin measurement and length on the stock rods? Pics from all sides/angles would be much appreciated.
    Thanks.
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    Re: Rod question
    ive got a set on the bench ill pick them up tomorrow and have them on here in the evening, the pin diameter is 21mm
    Re: Rod question
    thanks much!!
    May 27 2008
    Arvada, Colorado
    Re: Rod question
    [IMG][/IMG]
    May 27 2008
    Arvada, Colorado
    Re: Rod question
    May 27 2008
    Arvada, Colorado
    Re: Rod question
    there we go sorry it took so long im new to these things and well yeah so let me know if you need anything else and i think there the same if the part number is the same and it is (i have etka too and worked at a dealer ) then they are the same
    Re: Rod question
    great!! thanks for the help, it is very much appreciated.
    May 27 2008
    Arvada, Colorado
    Re: Rod question
    no problem
