Results 1 to 14 of 14
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Changed plugs to Copper, Now Rough Idle!!
    I changed my plugs to the NGK coppers and I am getting a very rough idle. Any ideas?
    I've read a lot about them and they are supposed to be pretty sweet for our B6's, so what's the deal?
    Thanks guys!
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: Changed plugs to Copper, Now Rough Idle!!
    what did you gap them to?
    Registered Member Two Rings quattro2003's Avatar
    Sep 29 2007
    2003 A4 1.8T Quattro
    Pittsburgh, PA
    I've read the gap should be at 0.28 or 0.32. I have no clue which one to choose. I have copper plugs but don't know what to gap them to.
    Veteran Member Three Rings Four Play's Avatar
    Mar 15 2007
    is full of shit!
    Texas
    I have APR S1 software and have mine gapped to .028 and haven't had any problems with idle or drivability...
    V8 Touareg - 1G TSI AWD - WRB WRX
    Senior Member Three Rings vc1492a's Avatar
    May 04 2008
    Knoxville, TN
    Im stock but I gapped mine to "0.032" and the car runs better with them. more power.
    however,
    this morning (its been a week and a half since I installed them), I started the car, rpms rose to 1100 for half a second, dropped to 700 for another half a second, and quickly rose back up to the 1100 rpm for the warm up. ran fine for the rest of the day too, I just think it nothing to worry about, but who knows?
    2010 A4 2.0T S-Line Cab (CVT)
    2004 Stage 2 Mini Cooper S
    Sold: OEM+ 2005 Audi A4 USP 1.8T
    Feb 17 2005
    Sarasota, FL
    Which NGK plugs? BKR7E? IIRC .32 you should be at on gap
    May 04 2008
    Knoxville, TN
    Im running BKR6E, .032 Gap
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by vc1492a View Post
    6E's are the same temp as stock but a shittier plug, get yourself some NGK BKR7E's if you want copper. If you want better plugs that last more than 3-5k miles, get Denso IK24's
    May 04 2008
    Knoxville, TN
    which exact plug are you using 04b6sport?
    here's a link that may help you, its from another thread
    http://www.audigeeks.com/forums/index.php?topic=56.0
    Jun 21 2008
    I have read that AudiGeeks post before, thank you. That is the reason I went with these plugs. Don't know why the idle is worse though.
    They are NGK BKR6E-11, gapped 0.032. My car is stock.
    Higher RPM seems pretty nice, 60-120mph pulls seem a lot nicer, but it runs a lot rougher when idled. I have no idea!!
    May 04 2008
    Knoxville, TN
    my car had a hesitation starting this morning... AGAIN. with the copper plugs.
    had the timing belt, water pump, and fuel filter changed yesterday (friday) AFTER the original hesitant start so it isnt that.
    might be the plugs, but not sure. Ill have to see how long this problem persists and maybe change the plugs soon
    Jun 21 2008
    Bump.
    I really need some advice here. That AudiGeeks post stated that the 7E's are not the best for my temp range (ie. stock) and they will actually perform less in my motor. Need to figure out why the 6E's are givin me shit!!!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by quattro2003 View Post
    Always start at .032 and if you get blow out just decrease the gap a little at a time. The larger the gap the more voltage is used since the resistance is larger, so this is why you want to start at .032 and then work down.
    Oct 27 2007
    In the lab
    its not the plugs... the bkr7e's were flawless for all 45k i drove last year... you just need to change them every 5-7k miles
