Page 1 of 4 123 ... LastLast
Results 1 to 40 of 127
    Feb 17 2005
    Sarasota, FL
    Alright I'm Running Out Of Fuel ...
    Well now that I know the fuel system is back in tip top shape, started upping the boost with the new turbo. I think Ive finally hit a fueling limit, now is it from the pump, injectors, octane, or something else Im missing?
    Used to run 27.6psi with the 3071R and never had an A/F problem, was always around 11.7-11.9 on high boost
    Here's a 20psi, T6, 3rd gear log
    Now A/F gets beyond my comfort @ 25psi, T6, was using 5th gear so the power oncome would be smoother and I could watch the boost and A/F better. Everything is good till the upper 4's then it starts to go lean (12.8-13.0) and I got out of it
    I dont think its the octane, no CF's Not sure if its the injectors, pump, fuel pressure ... any opinions?
    Thanks, Shawn
    Jan 25 2006
    A4 2.0T
    MD
    Re: Alright I'm Running Out Of Fuel ...
    Off topic:
    Are you happier with the car now, or still too slow?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    It is not leaner than my car runs...
    My A/F is .86 always
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by 400HPA4 View Post
    It goes up to .883 and I saw the wideband go as high as 13.0, thats nothing to worry about?
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Don Supreme View Post
    Off topic:
    Still too slow lol but feels much much better! Just the motor alone is better and there is a noticeable difference between the 3071 and 3076!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    With meth? No, on Cali 91 from ARCO? Maybe...
    Our cars can compensate for knock very well, just log your knock voltages to make sure that the sensors are torqued correctly and you are getting accurate values.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by A4ringedONE8T View Post
    Noticeable as in a dyno pull, QM time or a CAPS run? Quantitative results are the best...the butt dyno can lie.
    Mar 11 2008
    B7RS4 & e46Ms
    usually fuelcut is a pretty dramatic thing... can you log injector duty cycle? if you're not at 100%, you can point the finger at the fuel pump, as if your fpr could handle 27psi, it can certainly take 25psi...
    Feb 17 2005
    Sarasota, FL
    The motor itself is the most noticeable, runs much smoother, revs faster, just all around feels more solid. Other than that, straight up butt dyno talking! lol
    Feb 17 2005
    Sarasota, FL
    93 and meth yes, I didnt touch the knock sensors when the motor was out so they should be the same as before. What channel is that do you know?
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    log knock voltages shawn
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by 317ssayzarc View Post
    What channel?
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    It's not octane. It's not your injectors. (630cc right?) It's not pressure. It's most definitely your fuel pump. Im sure it's stock and the original right? Did you log with this file before with your previous setup? I can't remember. Either way, you should definitely start with your pump. It's a good investment either way.
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
    Oct 27 2007
    In the lab
    What channel?
    my bad, i need to slow down and think before i type lol...
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Silence View Post
    No one with a B6 has NEEDED an aftermarket pump yet
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Dirtybyrd seems to be doing fine on the stock pump and he is most likely making more power. It could be the pump though becuase I doubt it is the injectors.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Mar 19 2004
    Vegas
    If it's starting to fail, i.e. old, than you would definitely see this happen. Mine died on the freeway, just after I changed files and turbos. It requested more fuel and slowly I could feel power coming down. Like I said, it's not your injectors, or pressure. Log injector duty cycle and you will see.
    Cheers! David
    Mar 19 2004
    Vegas
    Besides that, noone has even shown a dyno over 330whp on a b6 that I know, so that may also be a reason why noone has NEEDED it yet.
    Cheers! David
    Oct 29 2005
    10speed
    San Francisco, CA
    - Clint
    Feb 17 2005
    Sarasota, FL
    There are a few of us making more power than that, its just getting time to go to the dyno
    Feb 17 2005
    Sarasota, FL
    WTF is that? Some new SEM?
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    How about your EGT?
    If you're less then 950 Deg C then theres nothing to worry about..
    Oct 29 2005
    10speed
    San Francisco, CA
    Plug n' Play SEM for B6s... using all factory sensors
    - Clint
    Mar 19 2004
    Vegas
    Btw, to log injector duty, log block 002. Then you have to do some math.
    Duty cycle = inj time / 1200 * RPM
    Cheers! David
    Mar 19 2004
    Vegas
    Not that I'm doubting that (remember I pleaded with you to get the 3076 from the get go for your power needs) but fact is, noone has shown a high dyno, therefore it's all speculation on the threshold of the pump at this point. It could be 350whp and it starts to take a shit. Who knows?
    Cheers! David
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    block 026 is knock voltages. Using semi solid "stasis" engine mounts I maxed my knock voltages all the time. With the street density 034 mounts I haven't maxed them out since. Not like that info does anything for you, just pointing out the fact since people always told me engine mounts do not effect knock sensor voltage readings...
    I see 950deg C all the time, damn elevation and heat!
    I'll be dyno'ing in 1.5weeks down in Cali. I hope to put out 370-380whp uncorrected with 550cc's and stock pump.
    Oct 29 2005
    10speed
    San Francisco, CA
    Thres a B6 in NJ hes on here but doesnt post much, hes at 350awhp but he upgraded the pump tho
    - Clint
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Clint, interesting development over on Vortex
    Some fast things and some slow things
    ~Josh~
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by mtbrider View Post
    I know right? I would have loved to have that thing man... I bet you could squeeze another 30whp over most tunes with this thing... people would pay an extra $1k for that easy, but its not even that much its cheaper
    - Clint
    Feb 17 2005
    Sarasota, FL
    Didnt feel like looking through the whole thread, how much is it?
    Oct 29 2005
    10speed
    San Francisco, CA
    $1400, not bad, and you can probably sell your ECU for a decent amount... I know Adrian has the ability to tune it also
    - Clint
    Oct 27 2007
    In the lab
    1400, and if you dont know the name kevin black, get real familiar
    Feb 12 2004
    Everywhere
    you can find used ecu's for ~$200 right now Clint
    Vote for someone else to be the guinea pig
    Shawn have you ever had your stock pump replaced or is it the original?
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by CO AVANT View Post
    Original, 58k miles
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I'm not saying that Shawn's pump is good or bad. But, my pump is 98k miles old and I run 630's. I know my car is about 380AWHP on pump 24psi and straight water, no meth. Also the stock o2 sensor will not read higher then 995 degrees. I do like the looks of that PnP standalone.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 12 2004
    Everywhere
    I know, I've hit 995deg C up here in the summer with the K04 (ecode fmic), GTRS (ecode & ER Comp FMIC), and T25 2871R (ER Comp). Turbos do not like being pushed to 23+ psi up here that's for sure lol. We all need to get real egt gauges anyway.
    Mar 19 2004
    Vegas
    Quote Originally Posted by dirtybrd View Post
    So you're on your original pump, never changed, and you have dynoed at 380whp?
    Cheers! David
    Oct 27 2007
    In the lab
    exactly the way i think when i hear you guys talking egt's lol
    Feb 17 2005
    Sarasota, FL
    EGT info = too late to do anything about IMO
    A/F shows a problem long before EGT's are affected
    Oct 27 2007
    In the lab
    i tuned timing on a stock car with an egt and peak torque readings, it can be a very helpful tool
