Results 1 to 13 of 13
    Veteran Member Three Rings Jurjen's Avatar
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    Is this normal? (video included)
    http://youtube.com/watch?v=uwx-vPgGm3A
    K, this is me @ 6th gear around 62mph, just flooring it. You see where it hits full boost for a second or two, dips off, then hits 15 again, is that normal?
    It does it a bit more drastically in other gears, and it doesn't do it all the time either. (heaven forbid our cars do anything consistent)
    Mods are 93 APR, and Forged 007 dv's.
    b5 s4
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Re: Is this normal? (video included)
    Everything looks normal to me. Does not seem to dip down to bad. When I think of dipping low is 5 psi or more and back up. Yours is fine, that is if your only running k03s. Your turbo spools up qiuck, then settle down and seems to hold just fine.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    Yah, only have the k03's, its a bit worse in other gears, but never as much as 5psi.
    b5 s4
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    normal..
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings YZracer's Avatar
    Sep 20 2005
    Scottsdale, AZ
    Looks good to me. That could be just a slight twitch of your foot that you don't even realize. I think it's just a slight dip in a normal power band.
    It's normal for Ko3's. Don't worry bout it.
    CURRENT TOY
    2013 TT-RS Ibis White - Stock for now......
    Sold:
    2010 B8 S4 Phantom Black: Stasis Touring Suspension Kit, APR Pulley, APR 93 Octane Pulley Tune, APR Full Carbonio Intake
    Parted and Torn down:
    2000 Black 6spd S4
    SSP Tuned PJK04 Stage 3
    Burned:
    2000 S4 Tiptronic (B5)
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    Quote Originally Posted by YZracer View Post
    appreciate the feed back, Im not so much worried, just a bit curious really.
    b5 s4
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    Seems normal, if you're paranoid check your DV's
    Jun 14 2007
    2000 S4
    Connecticut
    looks good... i mean tapering while the RPMs goes up is what you want by redline you dont want to be pushing too much with the stock turbos... also, you titled it "lag check". first thing is 6th gear @ 62 is going to take a while to spool it up. what RPM were you @ in 6th while hitting WOT? my guess 62 is in 6th is going to be less than 3k, like maybe 2700-2800?
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    2700-2800ish is about right, somewhere in there.
    b5 s4
    Jun 14 2007
    2000 S4
    Connecticut
    yeah so i mean its going to lag for sure.... how many miles on the car? if you are positive the car has no boost leaks ( you should check ) it can over-work the turbos and lead to premature DEATH! lol, but also things like diverter valves as S4ource mentioned, and N75 which controls the boost frequency.
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    you're misunderstanding the reason for my post, I was just curious about the dip in boost once I hit 15psi. Its drops only 1-2 psi in the video there, but in other gears @ other rpms it can be a bit more. But everyone says its normal - I wasn't worried too much, the car pulls fine, you can't even notice the dip in boost pressure.
    im not worried about boost leaks or dv's or anything. They're all fine (just replaced my tbb)
    b5 s4
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    It could be something you'd never think of like stock intercoolers pressure-dropping in the later RPM's and then the APR tuning adapting the boost pressure back up to compensate, thus appearing as a brief dip.
    Or something of the like...I guess it could never hurt to pressure test if you suspect something.
    Has the APR tune and/or your car always done this?
    Brilliant Black 2001 S4 - 6MT <3
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    that looks fine
    10 b8 s4 6MT sprint blue / black & silver
