OK, bought my OZ SL's off a friend a few months back... Tires had 6,000 miles on them, I put another 2,000 since having them on the car...
Before I bought the wheels I had the S in for the 55K service and asked them to check the alignment, they told me they did the alignment when they did the CPO inspection on the car about 1,500 miles before and said it was good. (with stock wheels).
There is a SLOOOOW leak, so slow that after putting 40psi in the front tire last saturday when they were moderately warm, it is still showing the exact tire pressure as the other side which I also put 40psi in... And on the inside of both front wheels the tread is gone... How is this possible if the alignment was correct? granted it was on the stock wheels but, isn't the total diameter of the tire the same, or is the stock set up have a slight negative camber up front for obvious reasons and the 245's just should not be up front?
The Wheels are 19x8.5 with 245/35 Falken ZE 452's and I had/have some rubbing at higher speeds and hit a dip in the road but, haven't heard any in quite a while...
I plan on (upon return from my deployment next spring) throwing a set of H&R C/O's on the car with a moderate drop...
I like the idea of running 245's on the car since the actual tire sticks out a bit farther than the wheel face to help with curbing the wheels and the bigger patch touching the road. I've been reading quite a few posts after a search regarding people running 245/35's and some have said they get rubbing, some have said they don't... All with mixed suspension set ups...
I'm looking at getting another set of 245/35's and read some of your opinions, looks like two of the highest rated tires are Michelin PilotSport PS2's and Vredestein Ultrac Sessanta's... I've found the PS2's on tirerack and discounttiredirect for roughly the same price... What is a good distributor of the Vredestein's? And what would I have to do to avoid rubbing on a slight drop, besides removing the fender liner bolt?
I apologize for the mix of questions/issues but, isn't that what we are here for?
Thanks in advance!
