Results 1 to 15 of 15
    Veteran Member Three Rings AUDILUX's Avatar
    Oct 16 2007
    B5 S4 / 335i
    What cleaning products....
    Just wondering what you guys use to clean your cars, especially paint. My car is black and I'm looking to give it a nice detailing job. Ideally, I'd like to remove as many of the fine scratches and imperfections as possible. Will a clay bar help with that? I'm thinking of ordering a Zymol kit detailing kit. What do you guys use? What works the best??
    My Garage: 4 door, AWD, twin-turbo Germans -
    • 2001 Midnight Purple RS4-widebody S4 (ASP Stage3)
    • 2009 Alpine White 335ix sedan
    Speed has never killed anyone, suddenly becoming stationary... That's what gets you. -J. Clarkson
    Veteran Member Three Rings CheesmoS4's Avatar
    Aug 24 2005
    Silver 01.5 Audi S4
    Northeastern OHIO
    Re: What cleaning products....
    i am pretty big into detailing cars i used to do it in high school at a autobody shop. I personally dont like the zymol kit too much residue left over and little tough to take it off. I would recommend if you are using a rotary buffer to get a Porter Cable from Phil at detail domain in the detailing forum! He gives a 15%discount to all AZ memebers with az as the promotion code.
    The process i went through for my car and my cousins imola b6 s4 was the following.
    Washed the car with Meguiars Gold Class car wash, dryed, then clay bar the whole car with megairs claybar kit. I then washed the cars again and used a air compressor or leaf blower to dry the whole car .
    I then used Menzerna Intensive Micro Polish, then Menzerna Micro Polish, and sealed it with Menzerna FMJ (all with the porter cable 7424 kit i bought from Phil at detaildomanin). The wax i used after the FMJ was meguairs yellow carnuba wax as the final process. You have to use tons of MICROFIBER towels.
    For the rims i used p21 wheel gel then scrubbed them with a boars hair brush, dryed. Then i used in my opinion the best wheel stuff, Adams Polishes 1 and 2. I spent about six to seven hours total doing both cars ( i also had my cousin helping me so it went faster).
    I know it sounds like alot, but the time and money you spend doing this to your car, you will be VERY happy with the results!
    All swirls and scratches were removed and the car turned out great. With your car being black you will see a really deep gloss to your car with this process, you really just have to look out for swirl marks when you do these steps because those show the most if not done right!
    Or if you dont want to do all that! Call PHIL he is in NJ also, and he does AWESOME and i mean AWESOME work just check out the detailing forum and you will see what i am talking about. His number is 201-233-0003
    Veteran Member Three Rings GetAudiHere's Avatar
    Mar 06 2006
    Minnesota
    Check out the detailing forum here on AZ.
    Also autopia.com is a great source as well
    Veteran Member Four Rings DolphinV8's Avatar
    Feb 18 2004
    A clay bar is used to remove contaminates from the surface of your paint. It is abrasive, so it might make your paint worse if not used properly. Menzerna products CheesmoS4 recommended are one of the finest products on the market today. Make sure you know how to use a rotory tool before you buy one. Again, it's a very good tool, but you can damage your paint badly if not used properly.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Quote Originally Posted by CheesmoS4 View Post
    You are fucking awesome. I'm going to order that stuff this weekend, btw what do you recommend for the interior
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    One word Griots
    http://www.griotsgarage.com/
    The best money can buy
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Senior Member Two Rings KryptoniK01's Avatar
    Nov 27 2006
    B5 S4
    Vancouver BC
    I've used many products and personally use either Zaino or Adams polishes with the Porter Cable and both work very well. I've also heard good things about the Griots but have not tried it out yet.
    :: APR V5 :: GIAC Tip Chip :: AWE Boost Guage :: Apikol Rear Diff Mount :: 710N's ::
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    I have also tried as many products as i can get my hands on. I only use Adams Polishes now. the machine superwax kit is fantastic for shine and durability. buy one of their large kits, it will cost you $3-$400 but you will get the porter cable polisher, all products necessary to detail the interior, exterior, and engine bay, microfiber, and DVD instruction (enough to do several deatails) Their micofiber towels are unbelievable. believe me there is a significant difference in microfiber, it really changes the results you get. Adam's is the perfect example of product and process. follow their directions and you will impress yourself with the results. good luck!
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    Meguiars Qwik Detailer, Lexol, and Vinylex....the Qwik Detailer is a gem, water beads off for quite awhile, fixed my buddies "black" car blues...
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    J Fonz Stage II+
    Nov 02 2006
    Western Mass
    how have none of you heard of Griots, try it and you will never again use the crap you find at autozone.
    ...For now
    clicky
    Oct 16 2007
    B5 S4 / 335i
    Quote Originally Posted by saucys4 View Post
    Wow!
    Thanks guys for all of the tips. Still not sure what to go with, since everyone seems to have a different fav...but ^^^^ pictures are worth a thousand words.
    Aug 24 2005
    Silver 01.5 Audi S4
    Northeastern OHIO
    Quote Originally Posted by TommyGunn View Post
    I personally like the einszett cockpit cleaners, and the leathermaster kit is amazing. This is where i get my stuff from and like i said before you get a discount for being a AZ member. http://www.detailersdomain.com/index...TS&Category=21
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    You should also check out Einszetts full line. They arent very expensive but the results are very nice. Einszetts interior stuff is awesome.
    Oct 16 2007
    B5 S4 / 335i
    I just ordered the 'essentials detailing kit' and the 'machine polishing starter kit' plus the 'accessory pack' from Adam's for $300 plus shipping
    I hope it is worth it!!
