Results 1 to 7 of 7
    Jan 06 2008
    Saguenay
    Brembo BBK 355mm
    Hi I got this kit on my car
    http://www.buybrakes.com/store/1B1-8002A
    i justwant to know where you guys taking replacement pad en disc for this BBK
    thanks
    Louis
    Mar 19 2004
    Hanford
    Re: Brembo BBK 355mm
    Try www.racetechnologies.com
    They are a direct Brembo distr. I got my pads there from them for the same kit. They also have the right pads to clean off your rotors before you put the new pads on.
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    You might also try:
    http://www.raceshopper.com/
    I got some pads from them.
    - Jim (Calif_Kid)
    Jan 06 2008
    Saguenay
    thank did you know the parts number ???
    Oct 14 2006
    Sunnyvale, Calif
    I don't recall the part number, but if you might go with raceshopper, I suggest just giving them a call at 800-733-8380. Their website has a price quote request section, but may as well just give them a call. When I bought pads from them, I got Ferodo DS2500 pads for my 355mm Brembo front brakes, plus stock rear brakes, but I have a B5 S4 (2001 S4). - Jim (Calif_Kid)
    Oct 14 2006
    Sunnyvale, Calif
    One tool that worked great for me when I needed to change the pads on my 355mm Brembo front brakes was the following tool. It made it very easy to get the pistons pushed back. It is kind of expensive (34.50 plus shipping), but worked much better than the usual $10 piston spreader tool. - Jim (calif_Kid)
    http://www.zdmak.com/wbstore/main.as...CTMP=1&LowCt=0
    Jan 06 2008
    Saguenay
    thank Jim...
