Results 1 to 34 of 34
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    Angry spent $8000 and car might be totalled?!
    So as many may have seen my post with my process of getting the car back together i had a big catastrophe this evening... long story but read it all
    So ever since i was driving it i would get a random three beeps. It would only happen sometimes and then go away. I would look at the gauges and they all looked normal and the car acted just fine. My LED display is totally shot so i couldnt tell why it was beeping. When i turn the car on i can see the yellow top part that says "OK". Oh and the beeping happened at all speeds so it wasnt the speed warnign thing going off. I pulled all the codes and the car was fine. no codes to be pulled... So today in the morning i went to the stealership and got two new keys cut and programmed, along with an alignment and a tierod. anyways...
    I was merging on to the highway tonight and got into traffic, got to the middle lane and went to pass someone. the car wouldnt accelerate that great and being the first time on the highway i floored it thinking the car wasnt that great with passing power. the car redlined and wouldnt shift and the car lost all power and i couldnt accelerate past 80mph. then the engine just died and i lost everything and was able to coast to the side of the road. I turned the key off and tired to restart and nothing. the battery was just installed last month and no idiot lights come on. my headlights light up just fine and all electronics work. When i go to turn the engine over i just hear one click and thats all.
    when sitting on the side of the road right after i pulled over, i smelled this really bad burning. didnt smell good at all and so i got a tow back to my home, another $170
    so intotal i spent $700 today and $8000 to get the car in its current condition.
    im afraid my engine seized up and that i will have to part out the car...
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    Re: spent $8000 and car might be totalled?!
    i would never own a german car out of warranty...just too expensive if something goes wrong.
    hope it works out for you and it's nothing that'll make you have to part with the car.
    Veteran Member Four Rings natalia's Avatar
    Jul 13 2008
    hula hoops
    Denvemolorado
    I cant believe this happened to you too! This just happened to me on Sunday I had to get my car towed and it ended up being the fuel pump. So that only cost me 50 because of the warranty, just when I thought everything was fine it wont accelerate like it usually does so now its back in the shop. GOOD LUCK
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    That sucks... Hope everything works out well for you!
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Oil pump failure?
    I hope the engine hasn't seized up.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Damn dude, I duno whats up with your whip. If you need any help with anything let me know. I will be up in Northbrook this weekend.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Established Member Two Rings Dlay's Avatar
    Apr 22 2007
    2006 A6 4.2 Quattro
    Greensburg, Pennsylvania
    this happened to me when my timing belt slipped. im sure you changed it but I figured id mention.
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    I have engine code P1113 which is Bank 1 Sensor 1: resistance too large.
    does anyone know what that means? i searched and could only find out what it meant which i already knew...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Means you have a bad pre cat 02 sensor.
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    i accidently posted this thread twice last night,,,im going to be on the other one of these,
    but here is my video of the car running rough this morning when i got it to turn over
    http://s14.photobucket.com/albums/a3...t=MOV-0002.flv
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    The heart attack to the car, terse and parlous.
    It's times like these that cause many people to end up with built engines and large turbos.
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    haha yeah some guy near me is selling his 2001 motor with the ko4, i know its not a BT but its more than what i have now.
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    QUESTION:
    this guy on craigslist is selling his 2001 motor and i have 2000, but hes selling it for $200. would this motor drop right in? or what will i need to change to get this motor to even work with my ECU and stuff?
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    how do we close this duplicate thread?!
    May 30 2004
    1997 1.8TQM
    $200 and it runs or is it a coffee table? A used K04 alone would be $200.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    2000 and 2001 cars have different blocks but same heads and both use ME7. I'm not sure how the fitment of the block would work out for your application as your coolant hoses might have to be swapped out too. You would need the ECU and possibly the harness for sure. It's not plug and play.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by nebone22 View Post
    2001 head has VVT, but that can be swapped out.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    If you can get all the engine parts w/ ECU for $200 then do it. Thats a smoking deal.
    Oct 30 2006
    B8 A4 Avant 6spd
    Could be something as simple as a large boost leak, motor will stall if its large enough, should've tried disconnecting the MAF and then starting the motor.
    Sounds exactly like what happened to me omw to school, turbo outlet hose popped off, lost all power, car started bucking, stalled, and coasted to a stop. Disconnected the MAF and limped the car to school, fixed it in the parking lot.
    What in gods name did you spend 8k on in a Tip car? You must have one wealthy mechanic at the moment.
    -18 718 GTS
    Jan 19 2005
    99.5 A4 1.8T, 07 Solstice GXP, 02 A6 3.0
    Reading ,PA
    Do a compression check on the motor and see what it is. From what you said I would kinda lean toward the tranny. Maybe a cracked flex plate? that si what it kinda sounds like in the video. Also kinda weird you floored it and the car wouldn't shift and hit redline, if the tranny got "locked" between 2 gears in between a shift it would cause the car to lock up and shut off possible. the flex plate and tourque converter are alas spinning so even in park with the car not moving it could be making that noise. Just somethign you might watn to think about before buying a new motor.
    AEB block/O-ringed deck~AEB crank/shot-peened/profiled~Swaintech PPM coated bearings~Raceware main studs~Eurospec rods~ARP rod bolts~JE 9.25:1 pistons/swaintech PC-9 coated skirts~Raceware Headstuds~AEB Head/extrude honed~Ferrea valves~Ferrea dual valve springs~Ferrea Titanium retainers ~Eurospec 268/260 cams~Autotech adjustable cam gear~ Borg Warner S362 .70A/R ~Custom tubular manifold~Tial 38mm wastegate~Custom FMIC~AEM Water/Meth~034 EFI stage IIc ecu~MSD DIS 2~World-Electronics PBC-1
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by schearer225 View Post
    a trans wouldnt cause the engine to shut down
    - Clint
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    Quote Originally Posted by Militant-Grunt View Post
    haha i did all the work myself. but from coilovers, to fender, bumper, timing belt kit, rims tires, and the price of the car, oh and alignment, exhaust, vac lines, TB, MAF, new keys, it all adds up man
    i did do a compression test and it all came back at 160 so my cyls are fine and the plugs look good. I took a look at the turbo and there is no shaft play and can be turned very easily.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by willowtreexx View Post
    that doesnt count my friend
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    haha fine ;)
    then i spent $5500 worth of parts to fix the thing
    and have $8000 tied up in it.
    Oct 30 2006
    B8 A4 Avant 6spd
    And the price of the car... makes sense now. I was about to say if you spent 8k on repairs..
    -18 718 GTS
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    ha yeah,
    Im trying to figure out what to do now. I have to leave for school in 2 weeks and the car is now in great condition but the motor is being goofy. I dont have the tools time or knowlege on how to rebuild a motor.
    I just got new in the past month, rims and tires, boost guage, fenders, bumper, exhaust, batter, timing belt, detailing, DV, DP, H&R Coilovers, code reader, MAF, TB, alignment, Tie rods, brand new keys, water pump, thermostat, tensioner, belts, vac lines, perfect interior, all these things and i wonder if anyone would buy it in this condition and all these new parts...
    i really need a four wheel drive for the winter at school and all the driving in minnesota i do and chicago land.
    Jan 19 2005
    Reading ,PA
    Why not? If the trans locks up while the car is in any drive gear, motor won't spin if something is preventing it from moving. stick a 2X4 in a motorcycles rear wheel while the engine is running and it is in gear, it will shut right off cause the drivetrain staled it out. It seems kinda fishy that he mashed the pedal and the car didn't go anywhere (no down shift?) and when he had it going the car hit redline (trans not shifting) All the syhmptoms seem to point to a tourque converter since the tourque converter is what pumps the fluid in the trans (causing crappy shifts) also explains that weird noise while he car is idling, since the tourque converter bolts to the flex plate, which bolts to the crank, all 3 spin while the motor is moving. I may be totally off the mark, so keep us updated on what the problem was
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    Whatever your problem my be, buy that motor for $200.
    Hopefully you'll get it sorted out shorty
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    well i decided for this moment that i am going to be keeping the car. I am going to pull the valve covers and heads tomorrow to see what may be wrong and if nothing then pull the motor and see exactly what the problem is.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Quote Originally Posted by AudiSport12 View Post
    what he said.
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    if your compression is good, you probaby did not seize your motor. I would do like the post said above and check your fuel pump. Also look for your code on audiworld.com maybe you will find somethign there.
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    just thought i would post a pic
    also i posted in the classifieds that i want an ATW motor to put back in my baby. the $200 one doenst have a turbo and doesnt turn over... laaame!
    Dec 05 2007
    Link 1
    Link 2 (don't know what would be needed to make it an auto)
    Cheapest way to ship would be Uship.com. Just make sure to check the shipper's reviews and feedback.
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    Link 1
    duude youve been so fucking helpful lately i cant thank you enough!!
    Im inquired about both of them and im still looking. hopefully something will work out soon. Im so burned out im heading on a quick vacation for a few days. ill still be on here and still be active in my searching haha.
    i just got a 10,000lb engine hoist for free from one of my friends so im about to start tearing this apart before i depart.
