Results 1 to 24 of 24
    Veteran Member Three Rings wflan's Avatar
    Jul 07 2007
    Unhappy Abysmal Fuel Economy - Please Help
    So I have an 07 A4 2.0T M with around 17,000 miles on it. I just got chiped but this issue has been around for at least 500 miles prior to the chip and persists after.
    I'm used to getting 28-31 MPG due to a combination of where and how I drive. It's been this way until a little while ago when the MPG dropped about 30%. Now it's a feat to break 21 MPG.
    EX: On the way back from Whistler w/o traffic (basically a highway that happens to drop a kilometer along the journey) I managed 25.5. I've been to the stealership twice for this and despite me very clearly explaining something's very wrong and very different, they don't seem to want to do more than check for fault codes and send me on my way (or at the least their explanations of what they did were simplistic). I even gave them a recipt for 3/4 tank of gas where I was driving deliberately conservatively and got 18.27 MPG.
    What can I do personally or ask the dealership to do to fix this? In Vancouver, Premium's been hovering around $6 a gallon and I'm really ready for my low dispacement turbo four to stop acting like a very slow V8...
    P.S. I've checked cursory things like tire pressure (fine)
    Boulder, Colorado
    2007 Red A4 2.0Q MT w/ Premium Package, apr91 and sticky shoes.
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    Re: Abysmal Fuel Economy - Please Help
    im getting 14.8 according to my instrument cluster. im chipped with exhaust too. i consider it a win over my old chevy avalanche truck that averaged around 10 lol
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    I'm to lazy to crank the numbers to see what i'm getting, but the first 1/4 of the tank goes super quick for some reason.
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    i got 15mpg in my 02 a4...
    audis don't get the best gas mileage...but they make up for it by owning the road.
    May 11 2008
    Naples,FL
    I get atleast 25 city and 32 hwy ive gotten ridiculous reads when doing all hwy at 80 mph....check filters or run some fuel cleaner or racing fuel maybe to clean it out if you run your tank bone it may have had lots of build up in it......
    I had a 2000 bmw 330 and when it was idling rough the dealership told me to put a tank of "the cheap stuff in it" which i then did put 87 octane in and it fixed it.....don't understand why or how...
    2.0 T Quattro - 20% tint,hardwired 9500i,alpine 757 amp,alpine 12" type r sub,RS4 Sway,Giac X-chip, VMR 19 710's wrapped in Conti Extreme DW, H&R Coilovers .
    Nov 12 2007
    Grand Junction, CO
    I avg about 26.6 with mixed hgy/city. I can get about 32-35 mpg hwy, tho @ 70-80 mph.
    DUH! an Audi
    los angeles, CA
    i have shitty mileage, check pcv value seems to cause a problem with fuel
    -randy
    Jul 07 2007
    point is that it's a sharp departure from this car's historical performance and even when i'm literally driving down a mountain I can't get figures I didn't have to stretch for previously
    Boulder, Colorado
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Do you have stock mode? If you do, you might want to put it to stock and see if it helps, if not you may have a vac/boost leak somewhere.
    -Kris
    Jul 07 2007
    yeah, it started before I got chipped and isn't any better after (in either mode)
    Boulder, Colorado
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Is your air filter jammed? That could decrease it a little...otherwise I think there are some serious issues because that's just weird
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    i drive 2/3 highway and 1/3 in the city... the city i accelerate slow and average around 18, the highway i cruise around 75-80 and get around 26-28... i have 19" wheels which help a bit on the highway
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Ever thought it could be your driving style also?
    And oh yeah, if you know how to read dyno charts... compare a stock dyno vs. a "chipped" dyno output. That would actually answer ALL of your concerns.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Active Member Two Rings bhull35's Avatar
    Jul 17 2007
    2007 A4 2.0L w/Tip Black
    Hudson, Ohio
    I get 27.2 city and around 31 highway. Try running some Redline Complete Fuel System
    Cleaner. Use a complete bottle w/ one fill up, then about 1/10 with the next several, Bottle is has levels of graduations on it. Then see what your mileage is.
    [I]It's more fun to drive a slow car fast than it is to have to drive a fast car slow![/I]
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Quote Originally Posted by Brent27 View Post
    that probably made the ecu change the timing for the 87 and changed it back to normal when you put in 91 or premium
    TEAM|AXION
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Sounds like you have PCV failure: http://www.audizine.com/forum/showthread.php?t=153392
    I got mine fixed at Capilano after reading poor reviews on Open Road and Richmond. See Dan Gira...good guy and took good care of me.
    Established Member Two Rings Postman's Avatar
    Mar 23 2006
    2009 A4 2.0T 6MT P nothing
    Sacramento, CA
    Quote Originally Posted by AudiWxGuy View Post
    That's almost exactly where I'm at with those speeds and the mixed driving. Oddly enough it seems to drop under 70. Never driven that long though at 65, but it might actually be lugging the engine too much.
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    Quote Originally Posted by Quattro View Post
    -randy
    +1
    I see 30+ hiway all the time. Never lower than 22avg over 1000's of miles. I've replaced PCV twice and 3 of 4 coils in 11k miles.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Apr 04 2008
    2006 Audi A4 Quattro
    South East Connecticut
    I had a sharp departure from my normal mileage (6mpg drop) in the last tank. Took the car in and there is an issue with the fuel system that's going to take a few days to fix. Just waiting for them to get a loaner in this afternoon. One other point the dealer mentioned was that the car would have sounded a little bit louder due to this and he was right, it has been louder lately. My drop wasn't quite as substantial as your drop in mileage but definitely worth getting it looked at.
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    i need to take my car in asap
    i put 40$ in.. which is about 9.5 gallons.. and after about 150 miles my car needs to go back for gas! thats like 15mpg.. that cannot be right.. i feel like even if i drive 100% city it should still be much higher
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    gas mileage goes downhill after 60mph. 15mpg in a 2.0t means youre either racing or the car needs servicing.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    AWD_4TW
    Quote Originally Posted by RedS-line View Post
    Depends lol. If you have good throttle control it doesn't matter, not to mention you should look at the our 2.0T's stock engine dyno again...cause according to the power output the engine gets similar mileage between 60ish and 80 -_-
    Apr 04 2008
    An update on my car and it's sudden drop in fuel economy, it's apparently the cam lobe wear mentioned in the common problems thread (#4). It's going to take 15-20hrs in labor alone to repair (under warranty)... thank goodness I got a CPO. However, the benefits are that hopefully that fixes my terrible lag just after stepping on the gas (almost got me rear ended the other day while making a left turn) and I got an '08 S-Line loaner for the weekend. I like the paddle shifters and the front end has grown on me. :)
    Registered Member Two Rings KOU's Avatar
    Jul 30 2008
    '08 Ibis: S-Line ext & SE pack
    I just got my 2008 A4 2 days ago and my gas mileage is horrible! I really didn't expect it to be this bad. In 2 days of very very conservative driving almost HALF my tank is gone! I was thinking of taking it to the dealership and showing them?
    I have read in another thread that its because the car is brand new? I hope the mpg improves because I expected better gas mileage with this car.
