Results 1 to 8 of 8
    Active Member Four Rings EUROTEK//S4's Avatar
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    B5 A4 1.8T and B6 A4 1.8T engines the same ?
    01' B5 S4 STG.II TIP
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: B5 A4 1.8T and B6 A4 1.8T engines the same ?
    should be
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    Quote Originally Posted by aaaudiprotein View Post
    should be
    so swapping them wouldn't be a problem...?
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I know there are differences but I'm not sure what they are exactly. There are differences in the block and the water pump is different.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    if its a b5 up to 1999 its an AEB block with the 058 block and big port head... 2000 is ATW which is 058 block and small port head... 2001 is 06A block and would be compatible with a B6 swap and vice versa....
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    different motor
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Dec 19 2007
    York, PA
    AMB and AEB are not the same
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by 317ssayzarc View Post
    That is your answer right there.
    FWIW: The TT motors are based off an 06A block like the B6 AMB. I have one (AMU) in my Avant. You'll need the longitudional oil pump pick up, oil pan and accessories (ac alt ps etc)
    -Doug
