Originally Posted by
kastro
because of my sludge paranoia, i have to drive the car more then 5km before i stop.. no short stops barely.. like.. how long does it take the oil to reach boiling point?.. another thing i do is.. when i stop.. i dont shut off the car for like 5min? too long?.. for the turbo to cool off... i time it :P, am i crazy or those are good measures
a little overboard imo.
use a full/true synthetic oil and change it in regular intervals, I suggest 5k miles at most. I personally change my between 3-4k miles and I'm fully aware my oil is still good even at that point.
5 minutes is also a bit overboard, your engine/turbo cools down pretty quickly assuming you aren't tracking your car. you can easily log the temps using vag com by the way. If I'm driving it kind of hard, I will take it easy before I get to my destination and I may let it set for a minute. on a regular day, keeping things between 1.5-3k rpms I won't even bother unless I drove a long distance and the temps a bit high.
these engines aren't THAT bad, otherwise you'd be hearing about A LOT more sludge issues.
i don't see how what you're doing is hurting anything, so if gives you that peace of mind, do it.
$.02
