Results 1 to 23 of 23
    Jun 08 2007
    GLI
    Orlando, Fl
    Another BT build question.
    All I have left to do on my build is run my passenger side IC pipe to the turbo, I have a Racetec IC. I cant for the life of me get the pipe to come anywhere near the turbo. My guess is the Eliminator is a different size compared to the K03 that the Racetec was designed for. I have the newer version IC, (two aluminum pipes) one short and one longer and bent upward. I also have two 45 degree silicone connectors and one straight one. I have no pics but I'm sure you guys that have installed a BT can picture it. What can I do rather than sitting there and trying again cause it's not going to work. Every way I position them is no where near close enough. Thanks.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: Another BT build question.
    dont know jack about the racetec but I think I remember people having the pipe backwards which caused it to not line up. That might be from the previous version though, im not sure.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jun 08 2007
    GLI
    Orlando, Fl
    This one is two pieces which looks as though it will work but it comes nowhere close once you try and install it. I tried working from the turbo first at one point and I ended up with a 5-6 inch gap between the pipes and this was using all of the flex hose. I even moved the smog pump, I bent the bracket it was on and ran in front of it and I am still short of reaching the turbo.
    Veteran Member Three Rings Carbon's Avatar
    May 24 2005
    2004 E46 M3
    San Diego, CA
    i had a similar problem with my setup. the stock turbo outlet pipe was kinked pretty bad so i had one custom made
    03 A4 - Sold
    Oct 29 2005
    10speed
    San Francisco, CA
    I have the ER comp hotside FMIC pipes, bigger than the Racetec but should work with a reducer. $100 shipped for either the stock turbo one or BT one
    - Clint
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    ^^^^^ um don't you need those? Or do you have some how have a spare set?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by pondside36 View Post
    making a new pipe for the hotside
    - Clint
    Feb 17 2005
    Sarasota, FL
    I believe Racetec offers hotside plumbing for stock turbo and a different option for Elim/BT's, might want to check on that
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Well that makes sense then... and like Shawn said, I know I had to specify what turbo I had for my AWE FMIC.. to bad it is still a K03
    Feb 17 2005
    Sarasota, FL
    AWE = Racetec, so what I said I believe is the problem
    Jun 08 2007
    GLI
    Orlando, Fl
    No, I have the two piece hotside version which is made for an upgraded turbo.
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by A4Dit View Post
    You're doing it wrong then
    Jun 08 2007
    GLI
    Orlando, Fl
    Quote Originally Posted by A4ringedONE8T View Post
    I think you may be right, but I don't see how. I was on Race-tec' site and looked at the way they have it and don't see where I am screwing up at. I'll be back up there pulling my hair out at 8am tomorrow. My Dad said he may fabricate something so it will work out eventually.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Nothing Racetec had mated to my GT28RS. I had to kinda fab my own. Since when is the AWE a Racetec? It wasn't last year; AWE must've changed their design? Their pics on page two of the forum with all the propaganda shows a different IC than what my Racetec looks like, too.
    My 2004.5 APR Stage 3+ is SOLD
    Feb 17 2005
    Sarasota, FL
    The Racetec and AWE plumbing is identical
    Feb 28 2006
    Pittsburgh-Philly
    I don't see how it can be because the Racetech doesn't sit in the same spot from what I can see. Not that it matters to me; mine works and that's all I care about, lol.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I am a racetec dealer, have known the person that started the company since before he did start it and have never heard of any such thing.
    ER pipes are not going to work with a Racetec fmic since the inlets to the end tanks are not even close to being at the same angle.
    Saint Cloud, Fl
    I had to use a silicone elbow to get mine to fit properly. I used the elbo coming off of the turbo, let's just say it was fun.
    instagram ------------> low_enforcement
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I had pictures showing the orientation of the RaceTec hot-side piping but they are not uploaded and not on my computer (I'm traveling). You'll have to wait. However, shoot papacristou a PM. He has my photos somewhere.
    -Doug
    Jun 08 2007
    GLI
    Orlando, Fl
    Thanks guys, I got it worked out this morning. I think Racetec sent me too many elbow hoses and not enough straight ones (only two). I had to go to Amazon hose and rubber here in Orlando and buy a couple different straight silicones hoses to get the job done. Nothing is exactly bolt-on, I don't care what anyone else says.
    Saint Cloud, Fl
    glad you got it to work
    Saint Cloud, Fl
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
