Results 1 to 9 of 9
    Senior Member Two Rings S4Berry's Avatar
    Mar 17 2008
    Tejas
    B6 S4 Cabin Filter?
    Is the cabin filter on a B6 S4 located at the back of the engine compartment up near the passenger side firewall?
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Re: B6 S4 Cabin Filter?
    Correct.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Passenger side. Super easy to replace.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Mar 07 2007
    04 S4, blown 91 Mustang GT
    Indianapolis, IN
    I need to replace mine as well. I'm assuming I need to remove the decorative plastic shrouding over the air intake tube. After that is the cabin filter plainly visible or do I need to removed anything else?
    Sep 18 2006
    So Cal
    Guys it's a real simple process. Check it out.
    1st - Remove the plastic battery cover.
    2nd- Remove the rubber seal as shown. It's best to take this all the way off.
    3rd - Remove the plastic cover as shown.
    4th - You will now see the pollen filter box as shown. Simply unlatch the tabs, open the top and remove the old filter.
    Install in reverse order and you're done. The plastic cover in the third pic takes some shimmying to get back into place so that the rubber seal can go back on properly but it's not hard to do. Just take your time. This entire process should take no more than 5 minutes. Good luck.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Very easy to replace!
    We have plain paper filters here Paper Pollen Filter
    And activated charcoal filters here, which also remove odors! Charcoal Pollen Filter
    Sep 26 2006
    Southern California
    Quote Originally Posted by likewater View Post
    4th - You will now see the pollen filter box as shown. Simply unlatch the Install in reverse order and you're done. The plastic cover in the third pic takes some shimmying to get back into place so that the rubber seal can go back on properly but it's not hard to do. Just take your time. This entire process should take no more than 5 minutes. Good luck.
    YOU DON'T HAVE TO REMOVE THE RUBBER SEAL! The plastic cover is removed by slightly twisting it at one corner then pulling it out of the seal from one end to the other.
    Sep 18 2006
    So Cal
    Quote Originally Posted by Fuffler View Post
    True, but for someone that has never done this, removing the seal just makes it easier I think. And, it's so freakin easy to take the seal off and put it back on it's not a big deal.
    Mar 17 2008
    Tejas
    I appreciate the DIY likewater.
