Results 1 to 14 of 14
    Jul 22 2008
    2005 B6 S4 (6MT)
    Rhode Island
    Cat-Back Install using Rhino Ramps?
    I tried a search, but did not come up with a definitive answer.
    Can a cat-back system be installed putting the rear wheels on Rhino Ramps?
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    Re: Cat-Back Install using Rhino Ramps?
    The problem is you need to be able to get under the car up by the downpipes. If you have high enough ramps maybe. I put the car on jackstands and had plenty of room.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Yes, that is how I installed mine.
    The stock exhaust comes off in one piece and an extra hand/eyes will help when it comes to making adjustments.
    Veteran Member Three Rings 80CID's Avatar
    04 A4, 88 RX7 turbo, 12 MDX, 12 Grand Cherokee
    Houston
    yeah, I used those ramps also.
    Jul 22 2008
    2005 B6 S4 (6MT)
    Rhode Island
    Great, thanks.
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    I actually used my ramps today to make my oil change go easier.
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    what ramps are those?
    tia
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by cam View Post
    tia
    Rhino Ramps
    They sell em at just about every autoparts store.
    Try autozone.
    Oct 11 2007
    thanks, they will definately make oil changes alot easier. gonna have to get a couple of 2x6's cut though, cause i dont think my car being as low as it is will simply roll up on em.
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    Quote Originally Posted by mcster View Post
    Great, thanks.
    I did mine with ramps. it definitely takes longer than if you have it on a lift, but it's very doable on ramps
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    '19 s4, P+, Quantum Grey on Black
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
    Jun 02 2004
    LA
    don't know how low you are, but i've never had a problem rolling any of my cars up onto my rhino ramps (all of them have been lowered). the ramps have a pretty low approach.
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
    Houston
    Yep, I use mine when ever I can. It makes jobs that much easier.
    when done you just hang them on the wall.
    I almost need another set.....because my RX-7 is always being worked on.
    Apr 05 2006
    05 S4
    Dayton Ohio
    Quote Originally Posted by 80CID View Post
    If you installed an LSx you will no longer have that problem.
    I'm not saying, I'm just saying.
    Houston
    Quote Originally Posted by Jdubya View Post
    thats the direction I was heading but then I decided that I didn't want to invest that much more money and time.
    So the new plan is to buy a used C6 Z06 at the end of next year....need to save some cash.
    keep the 7....just to much fun
    drive the A4 everyday, good mpg
    Z06.....need I say more!
