Results 1 to 13 of 13
    Veteran Member Three Rings favianjanitra's Avatar
    Aug 05 2005
    A6 3.0T Quattro S-Line & VW Tiguan 1.4 TSI R-Line
    Balikpapan
    Car does not start, does not turn over either
    I left my car for a week and came back to her this morning.
    The car tried to turn over on the first couple of try but it didnt start
    After the second attempt, the car would not even turn over.
    It just made a hissing sound when I turn the ignition key like "shh shh shh" and no spark in the engine at all.
    what should I check for?
    Spark plugs? coilpack? battery? (it is an original battery about 4 yrs old)
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Re: Car does not start, does not turn over either
    Jump it and let it run a bit, turn it off and try to start again. If it doesn't work I would say battery. I don't know why anything else would go wrong while it's just sitting there.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    If you get a ticking noise when you try to start it, that's the battery. I found out the hard way in another country.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Aug 05 2005
    Balikpapan
    I am going to try to jump the car soon and replace my spark plugs.
    report back soon.
    I dont think I heard any ticking...all i could hear was hissing noise sounding like the starter.
    but i could be wrong.
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    battery, then starter, then fuel pump.
    USP CLUB MEMBER #686
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Weird.. this is happening to me also. Randomly happened after I installed a new DV. I believe it to be the fuel pump or relay
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Aug 10 2005
    04 USP
    Las Vegas
    Quote Originally Posted by phantom b6 View Post
    I saw your other thread. That make's no sense to me at all. Wonderfun audi's !
    Apr 02 2008
    LA
    LOL tell me about it... I think it just randomly decided to stop working at the same time as I was installing the DV.. leading me to believe that it was something I did, even though I only touched a vacuum line and a hose.
    Even further mystifying is that the ECU threw the "Check Sum Error" at the same time.
    Aug 05 2005
    Balikpapan
    tried jumping the car with the help of my friend B7.
    Car STARTED right away...warmed it up about 10 mins or so and shut her off
    Tried starting her again (this time without jump) and car did not start.
    This is a dead battery for sure isn't it?
    I am getting Optima Red Top soon!
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Running the car for 10 minutes will NOT recharge a completely dead battery. The alternator is not THAT strong lol. To truely test if it is finished or not you need to try charging it with a real battery charger. Unhook the car leads from the battery if you do this.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Drive it around, idling for 10min isn't going to do it.
    -Kris
    Aug 05 2005
    Balikpapan
    I was only testing if battery was the problem.
    I was not attempting to recharge it.
    I plan to replace it with a new battery
    Aug 05 2005
    Balikpapan
    Just installed a new Optima red top 35 battery.
    Car starts great but there are a few issues.
    ESP light is on. do i have to vag it?
    keyfob is not working at all. I had to manually lock the doors.
    My APR chip is GONE!!.....is this common? now I wonder if they are going to charge me
    for re-flash.
    thanks for all your help!
