Results 1 to 15 of 15
    Senior Member Two Rings my01s4's Avatar
    Mar 06 2007
    Des Plaines IL
    Question regarding Removing A/C Condensor? For FMIC
    My AC isnt working properly in the car and i would like to remove the ac condenser to save an inch for the front mount that i will be installing as soon as it shows up.
    how difficult it is to remove the condenser completely. i always see people just put them aside. i want it off. is it just quick disconnect. i don't care is i lose all my freon, can i run it without the condenser in front of radiator is my question?
    01.5 S4 Black Avant (6MT)K04's:AWE GIAC 3:APR BiPipe:UUC VM3:Forge 007's
    (R.I.P.)
    00 Black S4 (6MT)K04's:AWE GIAC 3:APR BiPipe:UUC VM3:Forge 007's:DTS:STaSIS TrackSports 600/700:Sport Package:JHM SS:RS4 Knob:
    2001 Audi S4, Nogaro(TiP), Giac X 93
    Veteran Member Three Rings AielloS4's Avatar
    10' S4
    BOSTON
    Re: Question regarding Removing A/C Condensor? For FMIC
    i took my ac out and it gave me a bit more space with an RS4 bumper w/o it. A stock bumper with FMIC should not touch at all, barely with the condensor out.
    EUROSPORT-PERFORMANCE
    www.eurosport-performance.com
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Quote Originally Posted by my01s4 View Post
    If your AC isn't working replace the expansion valve right near the firewall, i may be clogged, then if still no AC replace the Compressor. But first check there is no DTC's in in the HVAC System.
    You don't have to remove the Condenser to install a FMIC
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    when i installed my fmic i also removed the condenser. While doing that i also removed the entire ac system to shed some weight and free up some rotating mass. it is very easy to remove completely. Just the mounting brackets and all 10 mm holding it up as well as the bracket that holds the ac lines to the core....
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Mar 06 2007
    Des Plaines IL
    Quote Originally Posted by awdbiturbo View Post
    what else did you remove from the ac system.
    even if it would work, i would never use it, just a waste of gas.
    cant wait for the Fmic and will be removing the clutch fan assembly.
    (R.I.P.)
    Mar 21 2008
    I love AC
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    i'm all about driving with the windows down, but sometimes its just too damn hot. or raining.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Apr 20 2004
    Boston
    Quote Originally Posted by AielloS4 View Post
    hey Tony its Rob (Eurodesign) i just spoke to my cousins... Appearently your freinds with them, Anthony El hayek and his cousin Lilo Aka Big spender hahaha
    Jul 11 2007
    Chicago
    My01S4 - I am in Morton Grove and I can help you out on the FMIC if you want...
    Shoot me an pm and we can talk....when did you plan on doing this?
    What kind of piping did you get?
    Old "Casa - 01 S4 - Homebrew Stage X - K03/16 - FMIC - Autospeed Motor Mounts/Tranny Mounts/DTS - Stern Power Ring/Rear Differential Poly - XS Power Exhaust - JHM Shifter/Solid Link/Delrin/3rd Detent/Homebrew Shifter Knobbie weight - Homebrew SMOC -"
    New "07 Infiniti Black Sedan G35s 6MT"
    Feb 17 2008
    Ottawa Ont.
    black interior car with muggy ottawa summers? no way you could get me to remove it.
    hell i keep it on when im racing too.
    10' S4
    BOSTON
    haha yeah i know them..i was with them in the stands at waterfest for a little bit. I was in one of the parking lot meets on sat night and I saw you drive by us. I waved but I dont think you saw me.
    Apr 10 2008
    Quote Originally Posted by looseboost View Post
    I love AC
    x2 taking out the ac is the worst thing ull ever do, u will regret it later on. i did the same thing on my corrado once and boy i wish i never did.
    Senior Member Two Rings nocturnals4's Avatar
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    Quote Originally Posted by Klum00 View Post
    or women
    Mar 06 2007
    Des Plaines IL
    i refill the freon and after 2 weeks its warm again. i dont know what it could be?
    (R.I.P.)
    Mar 01 2006
    Kitchener, ON
    You likely have a leak in your system. Check your pressure on the low service line. (farthest to the right line) Should be greater then 0 or your AC shuts off.
    Put a dye in it and you will find the leak.
