Taken from GPOP's site:
"Parts Warranty
All of the parts in the rebuild kits carry a 12 month/50,000 mile warranty against defects in the material or workmanship. The warranty would not cover damage to the parts due to oil related problems, improper installation, foreign object damage, or the like. In order to warranty a part, it must be returned to us for inspection. In most cases, we would then need to forward the part to the manufacturer in order for them to do their own inspection which would be done by a highly qualified engineer. This isn't a long process, but does require a little time....about a week to ten days.
Turbo WarrantyWe warrant our turbos to the original purchaser against defects in the materials and workmanship for:
*Stock Automotive & Diesel Applications: 12 months
*All Performance Applications: 6 months
This warranty does not cover failure of the turbo that is due to oil related problems, installation problems, foreign object damage, any modifications made to the turbo by the purchaser, or if the turbo has been disassembled by anyone other than The G-Pop Shop.
If turbo failure is due to incorrect installation, foreign object damage, or an oil related problem we will still gladly take a look at the turbo for you, inspect it, and let you know what is wrong or what caused the problem. We can then proceed to take care of the repairs if that is what you decide you would like to have done. "
All things said and done, the turbo oiling/running fine, I think you are safe running the turbo to your normal specs and enjoying it without worry, and if it does pop it will be due to a faulty part on the turbo, not because of over-driving it or running it dry.
