Results 1 to 35 of 35
    Senior Member Two Rings TheReflex79's Avatar
    Oct 08 2007
    1998 Audi A4 2.8Q, '04 Nissan XTerra
    Alexandria, VA
    painting the chrome window trim?
    This past weekend I painted the chrome trim on my grille with plastidip. Now I'm thinking about painting the chrome window trim. Has anyone tried it yet? I know it would be a pain to take it off or replace it, but I'm sure if its masked off right it would turn out good.
    I've just never been a fan of chrome trim, especially once the windows get tinted.
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Re: painting the chrome window trim?
    Sounds messy to do it still on the car; best bet is to take them completely off, properly prep, then shoot them.
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    well it's just plastic so if you sand it down and polish it, it'll be less messier than painting. i never really paid attention to how they're attached but is there a crevice after you remove them? if not, just leave them off. weight reduction lol
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    chrome is ballin didnt u hear
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    What I have seen people do is cut electrical tape to go over it.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 08 2007
    Alexandria, VA
    By reading past posts, the trim cannot be removed without completely destroying it. Being properly masked and prepped, it should come out ok. I'm just not sure if I should use the plastidip, or spray it it with a satin black. I just am getting tired of the old man 'luxury' look of the 2.8 lol
    Oct 08 2007
    Alexandria, VA
    Quote Originally Posted by biketsai View Post
    I'm not sure if I could ever do that, I think after awhile it would look hack lol
    Dec 05 2007
    Go for it. It's plasti dip. If you mess up, just peel it off till you get it to look OEM. It's not like real spray paint.
    Oct 08 2007
    Alexandria, VA
    That's what I figure, only thing is that the plastidip does have alittle texture to it...but the nice thing is that it won't chip like regular spray paint might going on chrome!
    Dec 05 2007
    I attempted the plasti dip on my grill yesterday and it came out terrible. I got so upseat that I just ripped it off and said **** it. But I will attempt again today. I will have to mask it better. But what really sucked was getting a good amount of coats on. But it would need to cure a little before applying another coat. When I tried to remove the masking tape, it peeled up some of the plastidip and then it made it uneasy looking.
    I think this time I will do the same, but maybe go at the edge of the masking tape with a razor before peeling it off. So it won't pull up the plasti dip.
    Oct 08 2007
    Alexandria, VA
    Is it the chrome on the grill that you are painting? The easiest thing to do it just to remove it. I just scuffed alittle, then put on about 4 coats of plastidip, 30 minutes apart. Mind you it was about 85 outside, and 90% humidity! lol But I figure that with the chrome trim, if I mask it off good, I should be ok. I'm just not a big fan of the texture that the plastidip has, but I think it'll hold up better.
    Dec 05 2007
    I did not know you could take the trim off. I will look at it now. How do you take the trim off. Or do you mean to take the grill itself off the car?
    Jun 04 2004
    fairfield cnty, CT
    you know what works? drop in a 1.8t, trim turns black....OR drop in a 2.7t and the trim turns gunmetal. your choice.
    Oct 08 2007
    Alexandria, VA
    No you can just take the chrome trim off...there are about 6 tabs on the top and on the bottom....and 2 tabs on the left and right side of the grille. Try a search to see if there are any pics to take it off. But once you unhook the clips on the top and bottom, just try to slide the chrome down and it should come off.
    Oct 08 2007
    Alexandria, VA
    Quote Originally Posted by ModifiedA4 View Post
    Yeah if I was to drop in a 1.8L, something else would be dropping to my bank account! lol
    Dec 05 2007
    Cool, I did not even know that. Just sprayed my first coat. Thanks man .
    Oct 08 2007
    Alexandria, VA
    NP, much easier then taping everything up! Only thing I'm leaving chrome is going to be the front and rear rings.
    Dec 05 2007
    If you do paint the trim of the pillars and door surround, make sure to use a razor (at edge of masking tape and not cut too deep to cut paint) when peeling away the masking tape. If you don't, you could easily lift off the finish as it tends to bond together.
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    To do it properkly, take your time, mask off the car with painters tape and newspaper.... scuff/sand the trim lightly, then clean of residue. I'd use a coat of plastiic adhesive promoter as the primer, then after tacky, use black plastic dip in a spray can. It will look like its the black rubber trim when finished and also wont chip or peel off. Any over spray can be removed with a clay bar.
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Oct 08 2007
    Alexandria, VA
    It's exactly what I planned on doing...do you really think I should use the plastice primer, or if I scuff iut up, should that be enough?
    Mar 15 2006
    Should be good enough, however I always have a can of the Plastic Adhesive Primer laying around, so why not throw on a layer of that, better safe than sorry (doing it again later down the road)
    Oct 08 2007
    Alexandria, VA
    Good idea....any idea of where I can get it?
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    i wish i could put that chrome trim on my 1.8t :(
    2014 Audi S4 DSG
    Oct 08 2007
    Alexandria, VA
    Quote Originally Posted by bronz View Post
    Are you bring serious??? When I got my car, that was one of the first things I wanted to change. It just looks too much like a old mans car especially being brown! Lol
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Why not just go to your local Viynl sign shop and ask to buy some scrap black All-wheather?
    Then just cut and stick and it will never fade or peel unless you take it off. I bet you could buy scraps for less than $15 for all the trim.
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Veteran Member Three Rings Davect06607's Avatar
    Apr 07 2007
    Bridgeport, Ct
    I like my chrome...
    '05 S4 6mt- Jhm 93 tune, Jhm IM Spacers, H&R c/o's, 034 Density Motor & Trans mounts, Hotchkiss Sway Bars f&r, Apikol snub & R.Differential mounts, 034 snub bracket, Jhm LW rotors w/ Hawk HPS, K&N, Piggies, FI Catback w/ 8" resonators, S.S. brake lines, 034 Density strut mounts, 034 MAF Hose, 034 adj. endlinks, RNSE, JHM Solid ss.
    Oct 08 2007
    Alexandria, VA
    I want something permanent....not something that I'll have to replace if someone taps it.
    Jun 12 2008
    Allentown PA
    Quote Originally Posted by TheReflex79 View Post
    See below again.
    Quote Originally Posted by 4A Play View Post
    May 02 2015
    Tacoma, WA
    I know I'm reviving an old thread but thought this would be useful for those interested.
    https://youtu.be/lLdj4mlDC_g
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I'm so glad my trim is black.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Veteran Member Three Rings q20v's Avatar
    Nov 12 2014
    2001 Audi A4, 2001 Audi S4, 1988 BMW 530i
    Ottawa, ON
    Just came across this site yesterday and plan to buy a roll for my E34 BMW:
    http://shadowlinetrim.com/
    Oct 31 2014
    NH
    2014 Audi S4 - 6MT
    2000 Audi A4
    Senior Member Three Rings DeathKing's Avatar
    Feb 15 2012
    New York/Los Angeles
    I used to hate chrome trim but then I came to a realization...It's all about the style of wheels. If you have any chrome or machine on your wheels, it looks very nice with chrome trim (both the windows and grill). Anything else and black trim is the way to go.
    JP
    Current:
    '17 VW GTI Sport | VMR V804 18x8
    Sold:
    '99.5 2.8 Sport | k0mpressed tune | Apikol/034 mounts | TSW Bathurst 17x9 et35 | Falken FK453 235/40 | Bilstein B12 Kit | Neuspeed 19MM RSB | Magnaflow 14816
    Oct 31 2014
    NH
    Well if you have chrome wheels you need new wheels.
    Established Member Two Rings ChrisBuckle's Avatar
    Mar 30 2015
    Minford, OH
    I've plasti-dipped my front grill and rear emblems. Very easy. Front grill comes off and apart. Rear emblems you just spray all over then just peel off where not wanted. Plasti-dip is very forgiving, try it, if u don't like it, peel it off.
