If your compressor took a crap, the likelihood of metal shavings being in the system are greater than optimal.
I'm unsure of what type of expansion device you have. IIRC it's an orifice tube, early B5's used them. If you do have an orifice tube, you should replace that as well. Normally they go for ~$8 and 99% of the time they're universal. The reason you should replace it is b/c the metal shavings will get caught in it, and either reduce it's effectiveness or clog it all together.
Any time you open the system, you're supposed to replace the receiver drier. I've gotten away w/ it quite a few times with it being open for 30-45mins. If the system was open for more than an hour, I wouldn't question replacing the receiver drier. The A/C will not function properly if the system is "wet". This is the idea behind putting the system in a vacuum. The vacuum lowers the boiling point of the moisture in the system. Thus causing it to boil, and be removed from the "sealed system". Text book says a minimum of 30min vacuum, and the system should be able to hold 28in.Hg of vacuum w/o any leaks.
My advice is to have the new receiver drier installed immediately before the Evac and Recharge. If you don't have access to the tools to do the Evac & recharge, I suggest having a "professional" do it. It'll cost anywhere from $45-80 for the Evac & recharge (plus the cost of refrigerant-R134a) and whatever labor would be to replace the receiver drier. Probably only .5hr on top of the Evac/recharge cost.
A/C stuff is expensive, I'd hook you up on a deal, but you're a few too many miles away
