Results 1 to 10 of 10
Thread: Horn Issue?
    Veteran Member Three Rings drunknmunky408's Avatar
    Sep 26 2006
    2001 A4 1.8T FWD - SOLD
    San Jose, CA
    Horn Issue?
    When I arm my car, I use to hear a beep but now it sounds like a "FART". did the horn blow?? Can I fix this?
    2001.5 Nogaro Blue S4 6spMT l Sports Package l Blue Alcantara Seats l APR Chip l Neuspeed Exhaust l Eclipse AVN6620 l AWE Boost Guage l AWE Pedals l NRG 230g Shift Knob l
    TEAM|AXION
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    Re: Horn Issue?
    i have the same issue
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: Horn Issue?
    that's kind of funny
    {99.5 Avant}
    Jan 24 2006
    orlando
    Re: Horn Issue?
    pour some bean-o in the gas tank...jk
    Senior Member Two Rings TheReflex79's Avatar
    Oct 08 2007
    1998 Audi A4 2.8Q, '04 Nissan XTerra
    Alexandria, VA
    Re: Horn Issue?
    If there is a high and a low horn like most cars, one of your horns is probably dead more then likely. That's why you're getting the farting noise.
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: Horn Issue?
    alarm horn IS in the back hehe
    Some can be adjusted. Proly rusted tho...
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    Re: Horn Issue?
    I had the same problem on my A6, bought a new horn for the rear next to the 6 disc cd changer and still sounded the exact same. Guess what my A4 does the same thing, if you find out please tell me.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    May 22 2008
    is full of crap
    sandville
    Re: Horn Issue?
    You can hook 12V directly to the horn and if it totally blows, it would be good.
    Have good or new honker?
    I would check for a bad ground and hot lead at the horn, the wires, and also the harness connections on the CL module for corrosion. If all looks and checks good, it must be the CL module, might have a bad relay or other part inside slowly going phhht.
    Sep 26 2006
    San Jose, CA
    Re: Horn Issue?
    Quote Originally Posted by MattzWarsteiner View Post
    12v batt or putting a new horn in is better?
    TEAM|AXION
    May 22 2008
    is full of crap
    sandville
    Re: Horn Issue?
    If you can get 12V to the horn with the + lead disconnected,you can test it using the cars batt rather than buy a new one. Once the horn is eliminated as the prob, you can look at some of the other items in the list of usual suspects.
