Results 1 to 6 of 6
    May 16 2008
    WA
    Name This Part! Does it See Boost?
    As you may notice there is a big crack near one of the ends. What i was wondering is, does this hose see boost pressure? AKA a source for a boost leak? It looks like it connects between the EGR valve and the Pancake valve. Looks like damaged hose number 1,001 lol Thanks!
    Is there any special name for this part, or should i just go by the number written on the side?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Name This Part! Does it See Boost?
    Just go get a replacement hose.
    ... we get EGR valves?
    The pancake valve should be the hard pipe closer the the coils than the one you circled.
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    That goes to your secondary smog pump.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Jun 01 2008
    Apopka, FL
    eventualy every hose or rubber component is going to fail, just replace it, there's nothing special about it should the dealer want $20 for it and if you can find rubber 90degree elbows like that. in a F/I car every component is subjected to lots of boost/ vacuum pressure if it runs off the block or inlet pipe in some way.
    May 16 2008
    WA
    thanks for the clarification, its appreciated!
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Hey slideways, where in WA you located? I may be able to get you a deal on parts...
    ΜΟΛΩΝ ΛΑΒΕ
