Results 1 to 22 of 22
    Registered Member Two Rings
    Jun 04 2008
    MA
    It just cranks and cranks but no start
    Its a 2000 S4 with 124k miles. Was in a collision which damaged the passenger front door, passenger bolster airbag and side curtain were deployed. Original ECU has REVO software and thought maybe it was a problem with that so I got another A-Box with GIAC X software with no results. Car will just crank and crank but while cranking everything will get a power loss and then continue to crank till it does it again. Here are the codes that I got from a scan.
    VAG-COM Version: Release 311.2-N
    WSC 02756 790 00000
    Control Module Part Number: 8D0 907 551 A
    Component and/or Version: 2.7l V6/5VT G02 0003
    Software Coding: 06611
    Work Shop Code: WSC 06325
    2 Faults Found:
    16705 - Engine Speed Sensor (G28): Implausible Signal
    P0321 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    WSC 02756 790 00000
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 8D0 907 551 A
    Component: 2.7l V6/5VT G02 0003
    Coding: 06611
    Shop #: WSC 06325
    2 Faults Found:
    Readiness: 0110 0101
    Address 08 -------------------------------------------------------
    Controller: 8D0 820 043 P
    Component: A4 KLIMAAUTOMAT D56
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8D0 920 980 DX
    Component: B5-KOMBIINSTR. VDO D07
    Coding: 02262
    Shop #: WSC 00000
    1 Fault Found:
    00771 - Fuel Level Sensor (G)
    30-10 - Open or Short to B+ - Intermittent
    Address 35 -------------------------------------------------------
    Controller:
    Note: Can't Synch Baud Rate
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06325
    4 Faults Found:
    01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
    35-00 - -
    01381 - Alarm triggered by Anti-Theft Sensor: Rear Right
    35-00 - -
    01382 - Alarm triggered by Anti-Theft Sensor: Front Left
    35-00 - -
    01383 - Alarm triggered by Anti-Theft Sensor: Front Right
    35-00 - -
    Address 56 -------------------------------------------------------
    Controller: 8D0 035 195 A
    Component: Radio D00
    Coding: 00115
    Shop #: WSC 06325
    1 Fault Found:
    00856 - Radio Antenna
    36-00 - Open Circuit
    End -------------------------------------------------------
    I checked the engine speed sensor which is above where the driver side axle goes into the tranny and it wasnt disconnected or anything.
    Would the air bags being deployed cause it not to start?
    I also ran an output test and it came up with injectors 1-6 short to ground. Not really sure what the output test does. Any help as to where I should start looking?
    Senior Member Three Rings qtek16's Avatar
    Jul 18 2004
    01 s4, 11 Yukon Denali, 08 TBSS, 94 300zx, Sold 01 A4
    Re: It just cranks and cranks but no start
    Quote Originally Posted by Frizo View Post
    WSC 02756 790 00000
    2 Faults Found:
    WSC 02756 790 00000
    Coding: 06611
    Shop #: WSC 06325
    2 Faults Found:
    Coding: 02262
    Shop #: WSC 00000
    1 Fault Found:
    Controller:
    Coding: 00101
    Shop #: WSC 06325
    4 Faults Found:
    35-00 - -
    35-00 - -
    35-00 - -
    35-00 - -
    Coding: 00115
    Shop #: WSC 06325
    1 Fault Found:
    the speed sensor itself is bad or the crank sensor--See up there where it says voltage to low-- most likely bad--
    Jul 18 2004
    also looks like from the last part that the ecu/alarm is in immobilized mode--
    Jun 04 2008
    MA
    Quote Originally Posted by qtek16 View Post
    Is there a way to test them or just replace both the speed sensor and crank sensor?
    The speed sensor is the one at the drivers side axle location correct? What avout the crank sensor, where is it?
    thanks!
    Jun 04 2008
    MA
    How would I go about getting it out of immobilized mode?
    thanks, you guys are great!
    Jan 17 2008
    louisville
    any results from this?
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Quote Originally Posted by nogaroblueaudi View Post
    Prognosis: it's an Audi.
    Jun 04 2008
    MA
    Hey man.. Yes the car is up and running right now! Problem was with the Crank Sensor at the top of the bell housing near the drivers side turbo. Replaced it and the car started right up.. Are you having similar problems?
    Veteran Member Three Rings papuc14369's Avatar
    Apr 06 2008
    NorCal
    I have an engine speed sensor if anyone needs it. email me
    2001.5 Audi S4 - Santorin Blue - Stage 1 & dearly missed - RIP
    2000 Audi S4 - Nogaro Blue - Tial 770r - SOLD
    2001.5 Audi S4 - Black Avant - Bone Stock - SOLD
    2001.5 Audi S4 - Nogaro Blue Avant - Stage 3 RS6 Turbo - Daily Driven
    2000 Audi S4 - Laser Red - Sold
    Established Member Two Rings Sp@cE418's Avatar
    Jan 07 2008
    Audi S4 2001.5
    Quebec
    My car does the same symtoms (crank, crank, crank but after a while got finally started)
    My car did that 2 times in a week and one other time, the car shutted off while I was cruising at like 20 km/h just after a startup.
    But, i don't have the 16705 - Engine Speed Sensor (G28) code, only 18010 - P1602 Power Supply (B+) Terminal 30: Low voltage (Sporadic)
    My battery voltage is good and the battery haven't been disonnected for a while ...
    I cleared it and the code came right back away ...
    Any ideas ? Is it my Speed or crank sensor too ?
    Thanks !
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Keep an eye out for engine coolant temp sensors going out too, causing issues with starting.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Active Member One Ring AVERY895's Avatar
    Mar 21 2012
    harrisburg
    Quote Originally Posted by jeremy@matrix View Post
    This can cause a no start? I'm currently in same situation and remember seeing temp sensor at 130c when it's 20 degrees f out
    May 27 2004
    Portland, OR
    Quote Originally Posted by AVERY895 View Post
    Engine coolant temp sensor yes. If the coolant temp sensor is relaying incorrect data to the ECU(ie car doesn't know the cold coolant temp on a cold start), then the fuel inj's won't spray enough fuel, and engine will just crank and crank and crank. This could be an intermittent situation as well, since they're electronics.
    Are you talking about exterior/ambient coolant temp sensor? Issues with this will make your HVAC do all sorts of wacky things.
    Jeremy Williams
    Mar 21 2012
    harrisburg
    I was using vagcom and was flickering through reading and didn't think anything of it, I'll have to check it again and see if the reading is pegged still. Thanks
    Mar 21 2012
    harrisburg
    Can't thank you enough, was just going to get it towed to the shop I work at tomorrow but now I don't have to. Checked coolant temp was at 269 F, disconnected it and It instantly dropped to -40F. Fired right up!!!!! The problem did start ever since the 15F weather came about this week. Again thanks for the tip
    May 27 2004
    Portland, OR
    Awesome, I'm glad I could help. Is your current ECT sensor black or green? All black's have updated to green.
    Jeremy Williams
    Nov 17 2012
    waterbury Ct 06705
    I have a 2004 s4 and my just cranks cranks but no start. Code reading are p0321 and p2231 any help with this ?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Nov 17 2012
    waterbury Ct 06705
    Where is engine speed sensor located? And codep2231 I couldn't find diagnostic of code.
    Nov 17 2012
    waterbury Ct 06705
    Hey buddy where is the engine speed sensor located I'm also getting a cold P 2231 that I couldn't identify on that website you gave me
    Mar 21 2012
    harrisburg
    yeah it was green but gypsie who owned it previously used silicone to seal it instead of the o ring casuing it to leak into senor connector
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by lamontS4 View Post
    Its in the tranny at about 10'clock right where the eng/trans meet
