Results 1 to 17 of 17
    Registered Member Two Rings
    Aug 20 2007
    2000 Audi S4, 2006 Yamaha R6
    Clermont Florida
    Help diagnosing via DTC's
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-00 - -
    17544 -
    P1136 - 35-10 - Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
    16684 -
    P0300 - 35-00 - random/Multiple Cylinder Misfire Detected
    16690 - Cylinder 6 Misfire Detected
    P0306 - 35-00 - Intermittent
    16689 - Cylinder 5 Misfire Detected
    P0305 - 35-00 - Intermittent
    16688 - Cylinder 4 Misfire Detected
    P0304 - 35-00 - Intermittent
    16687 - Cylinder 3 Misfire Detected
    P0303 - 35-10 - Intermittent
    16685 - Cylinder 1 Misfire Detected
    P0301 - 35-00 - Intermittent
    16686 - Cylinder 2 Misfire Detected
    P0302 - 35-00 - - Intermittent
    17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
    P1453 - 35-10 - - - Intermittent
    17536 -
    P1128 - 35-10 - Long Term Fuel Trim mult.,Bank1 System too Lean
    17538 -
    P1130 - 35-10 - Long Term Fuel Trim mult.,Bank2 System too Lean
    Does a new maf sound right...?
    Car was running good until i hit a misfire while driving one day, began idling 800ish not nicely had a small shake to the car, stopped at advanced checked the plugs, plugs where all good, attempted troubleshooting coil packs although did not seem to find one to be faulty, by doing this it may have thrown a few misfires on cylinders which may have not had misfires though
    Idea's or suggestions?
    Thanks in advance
    -Zac
    Zac O.
    50th aniversery Yamaha R6
    2000 Audi S4
    Dec 06 2007
    Calgary, AB, Canada
    Re: Help diagnosing via DTC's
    A new MAF sensor and a new pass. side EGT sensor sound about right...
    Aug 20 2007
    Clermont Florida
    Quote Originally Posted by The_Jerbel View Post
    done today, no change....
    would re-run codes although my monitor shit on me and my laptop is a mac :-\ (not supported)
    any other ideas?
    Zac O.
    2000 Audi S4
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Have you pressure tested?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 06 2007
    Calgary, AB, Canada
    Clear the codes and see how it runs.
    Aug 20 2007
    Clermont Florida
    replaced maf, cleared codes still runs like garbage, was unable to re-run codes though because my monitor went bad now (worst luck)
    is there supposed to be 5 wires on the pigtail for the maf? ive got 4 and the place where the 5th pin fron the maf would go into the pigtai ls broken although there is no wire going to the 5th port, could this be my problem?
    it has to be the maf in my opinion being as the maf code + the lean o2's, and i believe it showed something in common in betley between the maf and the EGT which also threw a code.....
    Thanks in advance
    -Zac
    Zac O.
    2000 Audi S4
    Jun 24 2008
    E46 M3
    Woodinville WA
    That fifth wire is for the Intake Air Temp Sensor incorporated into the MAF sensor, but most of the time (as in your case) Audi/VW uses seperate Air temp sensors, so only 4 wires hooked to the 5 wire sensor.
    I would take a real good look at the plastic crankcase breather hose assembly. The 00 model S4's had the REALLY shity breather hose assemblies. Depending on where it may be broken, it would/could produce a massive vacuum leak.
    C
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by Affinitive View Post
    C
    x2. check this out,they tend to go on 00's frequently.
    Dec 06 2007
    Calgary, AB, Canada
    Even if that was the case, it certainly wouldn't cause a bad MAF and a bad EGT code...
    Jan 29 2007
    08 S4 00 S4
    MD
    I'd pressure test the car if I were you. The MAF signal too high can be caused by a boost leak, which could explain your lumpy idle. I like to pull the ECU while changing the EGT sensors. Get your VAG-COM up and running too, otherwise, you're flying blind
    Jun 24 2008
    E46 M3
    Woodinville WA
    Vacuum leaks most certainly will cause false MAF faults and fuel trim faults. As far as leaking boost pressure type of problems, that would generally produce fuel trim boost leak faults as that would be an unmetered air leak and boost leak when developing boost. Unmetered air leaks and straight vacuum leaks can be a little decieving. Straight vacuum leaks will oftentimes produce both MAF faults and Fuel trim faults if the vacuum leak is severe enough. Unmetered Air leaks (leaks in the intake plumbing before the throttle) will often times only produce fuel trim faults. I would not suspect a boost leak mainly because there is no boost leak fault. These cars are pretty good about monitoring target and actual charge air pressures and there is not much tolerable difference allowed before faults start setting for charge air pressure leaks. Again, I would first suspect a considerable vacuum leak behind the throttle in terms of air flow. On a 00 model, the breather hose assembly routes all the to the front of the manifold next to the throttle.
    Definitely get vagcom going again as stated. When you do, post what kind of g/s you're getting at idle and load and the fuel trim numbers as well.
    C
    Jan 29 2007
    08 S4 00 S4
    MD
    I've had eleventy billion boost leaks and not one single charge air pressure code.
    I'd still do a pressure test, it's cheap and easy and will save you a lot of guess work.
    Dec 06 2007
    Calgary, AB, Canada
    C
    It would take a HUGGGGE vacuum leak to throw a MAF code. I've never seen it happen personally. Also, VERY rarely does a boost leak throw a code unless it's massive. The deviation has to be by ~3 psi before it'll throw a code.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Is the MAF rubber ring tightly fit inbetween the MAF housing and the airbox with both clips to hold them together. I'm missing mine at the moment (along with 1 clip) and those codes look the same as what I have right now minus the EGT Sensor.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    Quote Originally Posted by Rated S View Post
    My MAF is also missing the O-ring and the bottom clip and I don't have a DTC.
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by Jayco88 View Post
    Maybe because your not Stage 3? I had been missing it since a long time, but the DTCs only came up when I went full Stage 3. I can't really explain it.
    Aug 20 2007
    Clermont Florida
    will check the crankcase breather and boost leaks today, just got the new connector in for the maf......
    i cleared my codes after replacing the maf and the only code that still came up was still low maf signal, and i do have the o ring and what not on the maf itself.
    will post up results later.
    thanks alot
    -Zac
    Zac O.
    2000 Audi S4
